Wiring Loom builders......
Old Mar 10, 2009 | 12:53 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Wiring Loom builders......
What do you use for passing an engine loom through a hole in the bulkhead? I can't find a strong bulkhead grommet for this purpose. I think I want a normal panel grommet, but with a tail that can be built and sealed into the loom, if that makes sense. Suggestions?
Help!
Old Mar 10, 2009 | 01:03 AM
rstdave's Avatar
rstdave
Personally i used a 32mm rubber grommet i had in my van (i'm an electrician), as the 32mm ones are fairly hefty ad plenty of room for the loom and gauge hoses...however there's no tail on these, didn't see it as much of an issue as the hole was fairly high behind the blower motor so no chance of water getting in. Have a look at this site....they even offer free samples http://www.plastic-parts.co.uk/mss/m...S-6TMAT5-04034
Old Mar 10, 2009 | 09:03 AM
project rs's Avatar
project rs
you can use the one on drivers side in engine bay of mk3/4 fiesta's around 50mm with nice tail that can be trimmed to suit
Old Mar 10, 2009 | 02:15 PM
cjwood555's Avatar
cjwood555
Can you use a proper gland and sleeve the cables to give you a better bend radius?
Old Mar 10, 2009 | 04:25 PM
xr4x4rs's Avatar
xr4x4rs
go down a scrappy an cut the loom out of a sierra or granada that would give you what you want
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
IainRS1700T
Sep 25, 2015 06:44 AM
