Turbo cooler in a Cossie pics??
Mar 10, 2009 | 12:14 AM
Does anyone have a picture of a turbo cooler installed in a cossie engine bay!!???
Im just interested to see how you plumbed it in!!?
cheers,
Mark
Mar 10, 2009 | 07:38 AM
I believe it is just feed from the water return hose from the turbo to header tank, sorry no pics
Mar 10, 2009 | 10:11 AM
Its easy, just fit it inline with the feed from the turbo to header tank.
Steve
Mar 10, 2009 | 10:14 AM
thats what i thought guys, just fancied seeing an example
Mar 10, 2009 | 10:20 AM
heres mine not plumed in the pics but you get the drift.
Mar 10, 2009 | 10:32 AM
Are they Airtech rad's and coolers? What is the quality like? I have just bought the 60mm rad and turbo cooler
Mar 10, 2009 | 10:34 AM
Last Time, Get Off PF FFS
Mar 10, 2009 | 10:51 AM
Those pics have just confused me now!!
I have a long water pipe from the turbo along the front of the rocker cover!!??
Mar 10, 2009 | 11:14 AM
this is how my hose from the turbo to the header tank used to look. i think samco did it this way to replace the type that you have that goes over the rocker cover. you can see it coming from the turbo then going along under the slam panel then round to the header tank. then it was just a case of cutting the right bit of the pipe to go on the turbo cooler
Mar 10, 2009 | 11:35 AM
Superb quality and good results!! i swear by airtec
Mar 10, 2009 | 11:38 AM
Quote:
Originally Posted by
Stu @ Claims Care Centre
2nd that.
Mar 10, 2009 | 11:41 AM
The one im getting is an Airtec....
You guys swear by them...
hope i dont end up swearing AT them!!!
Mar 10, 2009 | 11:51 AM
markyd3
LOL
They are no problem to fit or plumb in
Steve
Mar 11, 2009 | 12:17 AM
my engine temp have never gone above the m on the temp gauge since i have fitted mine. used to go half way up the gauge. dont worry they work.
Mar 11, 2009 | 12:22 AM
Mark,just fitting one to my 2wd saff,better if you use 4x4 cossie water pipe
cheeRS stu
Mar 11, 2009 | 09:20 AM
kosienutter
There seem to be quite a few opinions on water cooling for the turbo.
Some are saying that you don't even need water cooling on a T3x turbo even on a track car, some say leave it on as standard and others are opting for a turbo cooler?
Is it more for the benefit of keeping your coolant temps down ( where you are using the coolant to cool the turbo ) or for extending the turbo life?
Mar 11, 2009 | 09:32 AM
STUCOS
cheeRS stu
cough cough,and mine,cough cough.
Mar 11, 2009 | 11:35 AM
Mar 11, 2009 | 11:48 AM
Old pic which you can just make out the cooler. Mines piped up through the power steering to keep that cool aswell....
Mar 11, 2009 | 12:01 PM
Mar 18, 2009 | 08:09 PM
Guys....
one more question on this....
Are we saying to plumb this in i need to cut down the S/Steel turbo return pipe that is normally situated on top of the rocker cover??
Mar 18, 2009 | 08:50 PM
throw the stainless one in the bin, and use a 4x4 hose, which is then cut in two pieces
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
RsS2daz
Aug 14, 2015 05:26 AM
