cosworth brakes
hi i am looking for some help i am building a fiesta cosworth and i am trying to wire the brakes up they are standard 2wd coswrth brakes with out the abs if any one can help would get good thanks
the abs loom is stand alone so you can just plug it in, powe iiiup with the battery and the ignition plus the additional wiring for the warning light and away you go
ver very easy in fact, i've g a few looms that i've taken out of cars
if you want just the abs master cylinder pump thing working ten yyyare better off just getting a normal servo from an all dsc sierra dohc without abs
Aug 14, 2015 07:29 AM
Red_bull
Aug 9, 2015 08:34 AM
