cossie greens
so got my estate running but splutters like mad between 4 and 6 k if i nail it its fdine but driving sensibly its deadful
they are definately cossies greens however my engine aint that modded it has a chip and 10 psi stage 3 t3 but thats all
will the cossie greens cause the splutter its on ofab management aswell
and wud it explain my 15mpg
what chip are you running?
to run then on ofab you would need a chip desighned to run them
cossie green injectors are way ott for your boost and spec best put your other injectors back in,
hth
hth
Russ Payne
Sep 25, 2015 08:29 PM
