running issuse
Old Mar 8, 2009 | 02:03 PM
cressy's Avatar
cressy
Default running issuse
my car will fire up but you have to hold the throttle right open just so it will tick over.if you try to rev it it just cuts out?can anyone help
Old Mar 8, 2009 | 02:05 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If your MFI then it sounds like an air leak mate.
Old Mar 8, 2009 | 02:15 PM
cressy's Avatar
cressy
on cossie management.could it be plug lead thats fooked?
Old Mar 8, 2009 | 02:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Your EFI so it's not an air leak then!
If you have to hold the throttle right open i'd say your lacking fuel rather than a spark problem.
Old Mar 8, 2009 | 02:18 PM
Danster76's Avatar
Danster76
Whip the plugs out. Do you have wettness?
Old Mar 8, 2009 | 02:35 PM
mart rs's Avatar
mart rs
he always wet! lol
Old Mar 8, 2009 | 02:47 PM
cressy's Avatar
cressy
they are wet mate?
mart fook offlol
Old Mar 8, 2009 | 02:49 PM
mart rs's Avatar
mart rs
Originally Posted by cressy
they are wet mate?
mart fook offlol
lmao
Old Mar 8, 2009 | 03:47 PM
Danster76's Avatar
Danster76
Mine was doing this before. Was pretty sure it was the engine temp sender fooked and telling the ecu it was -30 and so to gush the fuel through to compensate. Its round the back of the inlet manifold. I THINK the sendor is exactly the same as the fan sendor so you might be able to swap em round to check.
I didn't get this far with sorting mine out (long story) to say for 100% this was the cause but was pretty convinced and worth a go anyway. Sendors are at fords still about Ł20. Got mine a week or so ago.
Old Mar 8, 2009 | 04:39 PM
Gadget's Avatar
Gadget
Spanner monkey
Just finished installing the management this morning, fired up first time but sounds like it's missing, the management was off a running car so can't see that lot being a problem, and the monitor is showing sensors reading as they should. Fuel's there, you have to hold the revs for it to idle! Pulled each lead out 1 by one and the running gets worse so that's the ignition side ok, not tried a different set of plugs yet because 1, i don't have a set to hand and 2, cos the miss is that bad, you'd expect the end of the plug to be missing!! I have taken them out, cleaned and heated them though!
Every now and again it pops and there's a big air rush back from the charge carrier ( no top intercooler pipe fitted! )
Was thinking of checking the followers next, see if they have emptied themselves ( the engine's not really done much work for 8 months! )
Old Mar 8, 2009 | 05:42 PM
RSTurboSI's Avatar
RSTurboSI
get some 8m leads and cossie plugs, make sure the spark plugs are gaped correct,
and it should run fine, failing that your running lean
Old Mar 8, 2009 | 05:52 PM
Gadget's Avatar
Gadget
Spanner monkey
Gonna try and get a set of plugs tomorrow, Anyone remember what the part no. is of the good cossie plugs for the cvh's?
Don't think it's running lean, the management stuff was bought by Cressy and came from a running car so i'm assuming ( the mother of all fuck ups ) it was running ok!
AND,
the fault was there before the management change, the problem is, i didn't hear / see how the car was as the mfi stuff had been removed before the car was delivered and Paul ( Cressy ) has not seen / heard the car since the conversion
Old Mar 8, 2009 | 05:59 PM
RSTurboSI's Avatar
RSTurboSI
AND,
not sure on part number,
Cossie Plugs can stand around 350bhp and wont get spark blow out, which is when under alot of power the spark splugs stop firing,
But problem with your managment is that your ECU wont reconise the fack you chagned the managment and then chuck more or less fuel in, as your air mix maybe different compaired to your old Inlet..
Old Mar 8, 2009 | 06:30 PM
Gadget's Avatar
Gadget
Spanner monkey
A change of management includes the ecu mate, thats the whole point of the conversion, the fuel is managed by the ecu and controls the fuel dependant on the info from the air temp, coolant temp and map sensor ( which are reading correctly! )
And incase you are wondering, it's not my first conversion, just struggling as the car had a fault before it was fitted
Old Mar 8, 2009 | 07:52 PM
cressy's Avatar
cressy
finger crossed mate it`s a quick fix
Old Mar 9, 2009 | 09:23 AM
cressy's Avatar
cressy
hopefully trying new set of plugs later this week finger crossed that there the problem
Old Mar 9, 2009 | 11:41 AM
IANS2RST's Avatar
IANS2RST
try the cps & connections to it
Old Mar 9, 2009 | 11:58 AM
cressy's Avatar
cressy
do you mean the crank position sensor mate?if so gadget has just put all new cossie management on car.so very much dout it`ll be that but thanks alway
Old Mar 9, 2009 | 03:11 PM
RSTurboSI's Avatar
RSTurboSI
no i didnt question your clue'ness towards it, And i didnt relise or miss red the main reply which i wouldnt of noticed the ECU change
Old Mar 10, 2009 | 07:16 PM
Gadget's Avatar
Gadget
Spanner monkey
All running for those interested, when supplied the conversion was all there bar a crank trigger set up. ( only the 1800cvh crank sensor was there, no pulley or trigger ring etc ) so we used one of my discs and brackets with the cossie crank sensor, i had forgotten to swap pins 3 & 4 ( crank sensor ) in the ecu plug back round again!
Funny thing was, it suddenly dawned on me last night when i was having a shave
Old Mar 10, 2009 | 10:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I find things like that always pop into my head a strange times too! lol
Old Mar 11, 2009 | 05:07 AM
cressy's Avatar
cressy
glad it`s all sorted gary see you at week end to pick car up
when you next have a shave can you let me know the lottery numbers for saturday? LOL
Old Mar 11, 2009 | 05:58 AM
Gadget's Avatar
Gadget
Spanner monkey
I often think of those while having a dump, no luck so far though
Old Mar 11, 2009 | 06:53 AM
cressy's Avatar
cressy
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
