Actuator help....
Old Mar 5, 2009 | 05:26 PM
TIL13R's Avatar
TIL13R
Default Actuator help....
Im looking to put a uprated actuator on my t3 as mine is broke by pervious owner but there seems to be so many different types of actuator and im just getting so confused....??
I have been told to get a -31 Actuator but seems to be so many different companys that sell them..
What do you run on yours and what make would you recommend..??
Tiller
Old Mar 5, 2009 | 07:49 PM
rstdave's Avatar
rstdave
Any -31 should do the job, should all do the same job. Personally i've got a nice forge anodised one, they supply whatever strength spring you want and you can take it apart and replace the spring if it ever gets weak so should last forever!
Old Mar 7, 2009 | 11:37 PM
cjwilliams05's Avatar
cjwilliams05
I got loads lying about
Old Mar 8, 2009 | 06:09 AM
JesseT's Avatar
JesseT
Personally I like the garrett ones as they are more compact than the aluminum ones and the arm has a +/- 10 degress swing that makes it easy install and setup on a daily basis.
Old Mar 8, 2009 | 01:51 PM
addiction's Avatar
addiction
Use a genuine Garret one!!!!!
Old Mar 8, 2009 | 01:54 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
There is only one -31.. it's made by Garrett.. everything else is usually an inferior copy.. or not even a copy at all!
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
