Not getting any fuel
Oright, i have just put a new head gasket on my s2 escort turbo and put it all back together and when i went to start it, it just cranked over for a while and didnt even try to start, so checked if it was getting fuel and i have fuel coming through the filter and then for some reason it isnt coming through the metering head, i loosend the cold start bolt and fuel sprayed out fine but when i loosed the injector bolts that bolt into the metering head i dont seem to be getting any fuel coming through. The sensor is plugged into the metering head, im getting a fuel pump buzz , i have a quarter of a tank of fuel in ther car but i stil dont seem to be getting any fuel coming through. I also took the injector pipes completly of of when i did the head gasket but i put them all back on ok with the washers and everything, this wouldnt cause any problems would it.
anybody know what it could be.
Sounds like a problem in the fuel pump circuit. There is a relay, the oil pressure switch, the ECM, and a fuse. You will need a schematic to aid in diagnosis as well as a fuel pressure gauge.
_________________________________
____________
tips: cleaning would be great with car wax applicator
____________
