XR3i parts on an ERST?
Old Mar 3, 2009 | 06:21 PM
Kevin_Mc's Avatar
Kevin_Mc
Default XR3i parts on an ERST?
What i'm wanting to know is if the XR3i engine has the same flywheel and CVH block as the RST. Obviously the Pistons are different, what about the crank?
I know the heads are different but i have the right head already, just looking to get the flywheel, and bottom end ready.
cheers
Old Mar 3, 2009 | 06:23 PM
studabear's Avatar
studabear
bottom end won't have oil return for the turbo
Old Mar 3, 2009 | 06:30 PM
Kevin_Mc's Avatar
Kevin_Mc
balls, didn't think about that
Old Mar 3, 2009 | 06:37 PM
orionmojo's Avatar
orionmojo
you could weld it into the sump if your handy though, but for the expense and hassle it might just be easier to get an rs block.
Old Mar 3, 2009 | 06:39 PM
Kevin_Mc's Avatar
Kevin_Mc
yeah too right it's easier
i'm on the lookout for a full RST engine anyway but it was just on the off chance.
anyone know about the flywheel and crank?
Old Mar 4, 2009 | 07:55 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
i've got this scrap bottom end mate if its any good to you, flywheel is off and one of pistons is totally kerfooked but dont know is crank would be useable?
Old Mar 4, 2009 | 08:10 AM
Kevin_Mc's Avatar
Kevin_Mc
i'll give you a text Ross
Old Mar 4, 2009 | 11:13 AM
nigel b's Avatar
nigel b
crank is different
the oil return is only a drilled hole in the block,a tight tolerance for the press fit of the oil return
Old Mar 4, 2009 | 11:24 AM
Ade's Avatar
Ade
Fast Ford snapper
I've heard that the crank is the same on every version of the CVH.
Rods should be the same on the non turbo. Flywheel is slightly smaller as the RST takes a bigger 220mm clutch. XR has the smaller one same as the S1 RST
Head is also the same. Various different versions of CVH head, but apart from the S1 getting sodium valves there was never anything beter specifically given to an RS model.
Mc5506
Oct 5, 2015 09:57 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
