5dr central locking
Old Mar 3, 2009 | 10:03 AM
midgetgem's Avatar
midgetgem
rs2000 4x4 wanted!
Angry 5dr central locking
Have a mk1 5dr focus and my passenger front door refuses to lock or open with the remote locking. Cenral locking still works when you use the key from passenger side only but if this door is unlocked and you press the remote, the lock switch on the handle dosen't move and it keeps the car unlocked.Any ideas cos it'd driving me mad!
Old Mar 7, 2009 | 04:55 PM
woolford's Avatar
woolford
this worked with mine sit in the drivers seat and press both front dor locks at the same time do thid about 6times and it hopefully will work with yours.
Paul
Old Mar 11, 2009 | 10:56 AM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
The central locking solenoid in your door is shagged.
You're looking around the £70-£80 mark for a new one and it's a bit of a pig to do as the metalwork inside the door (once you've managed to get the doorcards and that shitty insulation stuff off) is razor sharp, the access is ridiculously tight (even more so on a 5 door) and you've got loads of little pushrods holding everything together so it's a fiddly little fucker of a job!
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
