fiesta rs turbo
Old Mar 2, 2009 | 02:43 PM
silversufer007's Avatar
silversufer007
Default fiesta rs turbo
Can anyone no i got a rs i like to no is it normal for rs turbo to smoke on start up for a few minutes then clears up any info would be helpfull cheers
Old Mar 2, 2009 | 02:45 PM
RichieST's Avatar
RichieST
Something to do with the oil feed pipe leaking into the turbo housing while its not running isnt it?
Old Mar 2, 2009 | 02:47 PM
paceo's Avatar
paceo
stem seals if the smoke clears when warm
Old Mar 2, 2009 | 02:54 PM
silversufer007
theres a new turbo on there and new valve seals and rings just smokes a bit on start up then its fine???
Old Mar 2, 2009 | 02:58 PM
Pete frst's Avatar
Pete frst
if nothings worn pal then it shudnt smoke on start up............
Old Mar 2, 2009 | 03:01 PM
silversufer007
you think it might need running in
Old Mar 2, 2009 | 03:04 PM
paceo's Avatar
paceo
blocked breathers and hoses then? check those!
Old Mar 2, 2009 | 03:09 PM
silversufer007
mate done it doing my head in i been told they all like it is that ture
Old Mar 2, 2009 | 03:24 PM
silversufer007
just looked my hose breather white gunk in there which i clean it before i put the new head gasket on??
Old Mar 2, 2009 | 03:26 PM
timhil's Avatar
timhil
no they dont does it smoke if you boot it whille driving?
Old Mar 2, 2009 | 03:36 PM
silversufer007
no not really its fine took up the street few times its ok only when i start it up for 2/3 min
Old Mar 2, 2009 | 03:47 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
What colour is the smoke?
Old Mar 2, 2009 | 03:50 PM
Pete frst's Avatar
Pete frst
my head gaskit went,and there was creamy goo in the oil cap,so check your hoses,smokeing on start can be a sign on a worn engine,but with new a turbo,seals, rings then it should be fine,are you happy with the way the new parts were fitted.....
Old Mar 2, 2009 | 03:59 PM
Oranoco's Avatar
Oranoco
My FRST only smoked once when we had it and that was down to th eturbo shitting itself after xx years of 7psi and then me suddenly telling it I wanted 15psi still I wanted that T3 anyway
Old Mar 2, 2009 | 04:01 PM
silversufer007
yer all the patrs was fitted tidy cant understand why i got white gunk in my breather pipe i clean it now i try it 2 moz just cant understand why it like that i had all new parts the dam thing
Old Mar 2, 2009 | 04:04 PM
silversufer007
white smoke mate
Old Mar 2, 2009 | 04:06 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Originally Posted by silversufer007
white smoke mate
Condensation?
Old Mar 2, 2009 | 04:20 PM
silversufer007
Originally Posted by pa_sjo
Condensation?
yer mate its like that got a bit off water in my oil cap
Old Mar 2, 2009 | 05:37 PM
paceo's Avatar
paceo
are you running a bailey breather then???
Old Mar 2, 2009 | 07:15 PM
silversufer007
no standard with little kn breather
Old Mar 2, 2009 | 07:35 PM
silversufer007
do you do a engine flush when you do the head
Old Mar 2, 2009 | 07:36 PM
silversufer007
whats the best oil 4 these cars???
Old Mar 2, 2009 | 08:01 PM
Pete frst's Avatar
Pete frst
im useing millers in mine,but a lot of guys on here swear by silkoline.............
is your car sorted now?
Old Mar 2, 2009 | 10:59 PM
silversufer007
no m8 not yet i give it a engine flush 2moz and clean my breather pipes i let you no m8 cheers
paceo
Feb 3, 2016 10:31 AM
carlo
24
Oct 5, 2015 08:20 PM
s1turboman
Aug 29, 2015 04:27 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
