intercooler help..pic
Old Mar 2, 2009 | 01:02 PM
morto's Avatar
morto
Default intercooler help..pic
hi all, what do you think has caused this on my tdci intercooler im thinking its not holding the pressure and this is why aim struggling for performance iv also got a very high pitched squeal but thought that was maybe the manifold gasket as it only squeals once its got hot after around 5 or 10 mins , ive covered over 600 miles on a new turbo, the squeal is very hard to track down were its comming from
Old Mar 2, 2009 | 01:05 PM
mechanic28's Avatar
mechanic28
looks like the clips were not done up tight enough to me!its it a siren type noise?
Old Mar 2, 2009 | 01:08 PM
Twellsie's Avatar
Twellsie
purely a guess, but, old turbo was fooked hence leaving oil in you intake system, the hose on the inlet to the intecooler was not sealed correctly and join between core/outlet piece has a split in it.
proberly way off the mark, lol
best bet is to get you intercooler pressure tested
Old Mar 2, 2009 | 01:16 PM
morto's Avatar
morto
hi the clips were tight enuff as you have to be carefull with plastic intercoolers , if you over tighten it snaps the plastic but will ensure there correct mate
Old Mar 2, 2009 | 01:18 PM
morto's Avatar
morto
spent alot of time on getting the old oil out b4 fitting new turbo but i do think its possibly a fooked core
Old Mar 2, 2009 | 05:27 PM
B19 JUB's Avatar
B19 JUB
im guessing its an 1800 tdci? regards to squeal id advise to take aux belt off see if it goes,could be water pump or tensioner possibly
Old Mar 3, 2009 | 02:34 PM
morto's Avatar
morto
all tensioners are new with cambelt and the squeal is deff comming from the right hand side and all belts are on left hand side, i can get a new intercooler for around 120quid or second hand off flea bay for 65 quid
Old Mar 3, 2009 | 03:25 PM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Any radiator place should be able to pressure test that for you. Might cost you a drink, but it'd be worth it to find out if it is fooked or not?
Old Mar 3, 2009 | 04:25 PM
andy escos's Avatar
andy escos
looks like your intercooler is leaking where the core meets your headers , i would take it to a radiator repair specialist they should be able to sort it .
Old Mar 3, 2009 | 05:14 PM
B19 JUB's Avatar
B19 JUB
right hand side erm dual mass flywheel maybe?
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
