MOT question!!!!
Old Mar 2, 2009 | 12:23 PM
rog's Avatar
rog
Default MOT question!!!!
Ok, quick one for you, when they put a car on the gas analyzer to test the emissions does it have to be up to normal op. temerature. i.e. let the fans cut in??? I would say yes at a educated guess, but is there anything stating this as fact??
Old Mar 2, 2009 | 12:27 PM
mechanic28's Avatar
mechanic28
yes the Mot guide lines specify you have to get the vehicle up to running temp and purge the engine before doing the emission test
Old Mar 2, 2009 | 12:29 PM
There is a question asked on the screen specifically relating to engine temp, ie is it up to temp, it is fairly common practice on some to let the fan come on then do test as soon as it stops, being just slightly colder than fully warm can cause a fail where a fully warm will pass, my mot man always does the above.
Old Mar 2, 2009 | 12:34 PM
rog's Avatar
rog
Ok, thanks for clearing that up! Helps alot!
Old Mar 2, 2009 | 02:35 PM
C4llyT's Avatar
C4llyT
Not had this test for last 4 years, is it right that you don't on a saturday?
Old Mar 2, 2009 | 02:42 PM
RichieST's Avatar
RichieST
My local mot place has a probe that they shove down the dipstick tube to test the temperature of the oil.
Old Mar 2, 2009 | 05:19 PM
The probe is there for cars that DON'T have temp gauges like KA, air cooled cars etc, otherwise a visual indication is suffecient.
Old Mar 2, 2009 | 05:21 PM
C4llyT's Avatar
C4llyT
Do you not just use a cigarette lighter to save time anyway, or was I trained wrong?
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
