st170 internals
Old Mar 1, 2009 | 05:09 PM
northenhunk's Avatar
northenhunk
bitten by the rs bug
Default st170 internals
what are the safe limits of the crank in terms of rpm (once balanced) on the st170
also what are the power limits for the standard pistons and rods?
Old Mar 1, 2009 | 06:52 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Si @ Sitech buzzed his engine a while ago and the datalog showed nearly 10,000 rpm without the crank letting go!
I'm planning to rev mine to between 8500rpm and 9000rpm - that's on a lightened, knife edged and balanced ST170 crank.
In all honesty, i'm not sure the ST170 crank is any different to a normal 2.0 Zetec one - i think the differences are in the rods and pistons.
You can run around 300/300 on the standard ST170 internals - first thing that'll let go is the ring lands!
Old Mar 1, 2009 | 07:50 PM
woolford's Avatar
woolford
well a normal blacktop crank is good for just over 500bhp
Old Mar 9, 2009 | 08:26 PM
northenhunk
thanx guys i'll be taking mine up to 7500 in normal conditions and might bump it up to 8 on rolling roads etc.
i'm not going to be anywhere near the 500bhp mark coz i'm keeping it n/a just going for a 2.1 bore and proper rods and pistons and a cr of about 12.5:1 and throttle bodies
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
