Focus rear disc conversion ??
Have been offered a rear disc set up from an ST170,whole rear beam with all discs and calipers still on.I have a 52 plate 1.6 zetec.Just wondering if it's a straight swap over or a hastle to change.
Any help appreciated.
Undo the 4 bolts that hold the hub / axle to the blade/knuckle and transfer the whole assembly each side, also the brake pipes.
And you need the hand brake cable for a disc setup as well.
So the rear beams are the same.?
The bloke who,s selling the rear set up says i should make him an offer.
Don,t know what there worth to be honest ,what do you reckon?.He hinted at around £150.
jason_nike
Aug 18, 2019 10:53 AM
Graceland
Jul 31, 2015 10:34 AM
