Ford Mondeo Help - Knocking Noise
Old Feb 28, 2009 | 06:05 PM
PeterLucas's Avatar
PeterLucas
Default Ford Mondeo Help - Knocking Noise
Anyone work for ford, know any common probs with them?
Knocking from OSR, cant find a thing wrong with wheel off (subframe bushes look fine). Doing my head in!
(52 plate hatch)
Thanks in advance anyone
Old Feb 28, 2009 | 06:08 PM
Csm's Avatar
Csm
Shocks are very common failure
Old Feb 28, 2009 | 06:22 PM
dojj's Avatar
dojj
Resident Wrestling Legend
shock
subframe bush
arb link
even a spring broken
Old Feb 28, 2009 | 06:46 PM
Marshin's Avatar
Marshin
could be a droplink
Old Feb 28, 2009 | 06:47 PM
AlexD's Avatar
AlexD
Post Miester !
I would go with a broken spring.....
Old Feb 28, 2009 | 06:49 PM
PeterLucas's Avatar
PeterLucas
Done a drop link to eliminate it, all bushes are fine, springs fine, arb fine. not loose trim in boot!!
Driving along slowly with rear door open its quite loud!
Will whip shock off tomo to check for play
Old Feb 28, 2009 | 07:04 PM
dojj's Avatar
dojj
arb rubber then?
Old Feb 28, 2009 | 07:09 PM
Csm's Avatar
Csm
Your spare wheel is screwed down properly ??
Old Feb 28, 2009 | 07:29 PM
PeterLucas's Avatar
PeterLucas
ARB bushes are all right and the spare wheels tight down. Shock off tomo.
Thanks guys
Old Mar 1, 2009 | 05:32 PM
PeterLucas's Avatar
PeterLucas
seized handbrake cable, causing pad to brake up. New pads and cable ...sorted
for those who are interested
borboyous
Aug 22, 2015 11:17 AM
