FRS has sprang an oil leek!!
Old Feb 28, 2009 | 04:00 PM
R5 COT's Avatar
R5 COT
Exclamation FRS has sprang an oil leek!!
I put the cat back ontoday for the MOT and noticed quite a lot of oil leaking from around the crank case breather, it's not coming from the valve itself but further back before the hose, has anyone had this problem before?!
Cheers!!
Old Feb 28, 2009 | 05:02 PM
RS16iDale's Avatar
RS16iDale
i think this is where mine is leaking from aswell,would like to know the cause
Old Feb 28, 2009 | 05:10 PM
R5AAL's Avatar
R5AAL
Mine also. Think it must be a factory fitted leak lol
Old Feb 28, 2009 | 05:12 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
ive heard thats a common fault mate.my s2 been leaking for few weeks.got round to checkin it yesterday and the sump was being held on by just a couple of threads on each nut
Old Feb 28, 2009 | 07:51 PM
R5 COT's Avatar
R5 COT
It's weird, whilst I had the cat off I took the heat shield off the crank breather case, and it only seemed to be leaking near there the breather hose goes?! used a mirror but still couldn't really see it?! It's bugging me! I need to take a good look at it!
Old Mar 2, 2009 | 06:19 PM
tarmac terriost's Avatar
tarmac terriost
the tin sump hasnt rotted through near that area?
also check pcv valve and the mini oil catch tank to make sure its not full
there is a seal on the pcv vent at thr front of the block
Old Mar 2, 2009 | 10:29 PM
R5 COT's Avatar
R5 COT
Hey, Replaced the old sump a year or so ago and the valve, but will check the rubber grommet seal it sits in....i need 2 take a close look this weekend!! cheers dude
Old Mar 11, 2009 | 07:30 PM
tarmac terriost
also check rocker cover gasket,
check oil return for the turbo not split
no probs m8ty
if slove problem lets us know
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
