PVR's in car recording....
Old Feb 28, 2009 | 03:58 PM
Spiky's Avatar
Spiky
Default PVR's in car recording....
Looking at setting up multiple camera on the car
i have found a device that take 1,2,3 or 4 inputs, and you can arrange the screen several ways, but my issue is, i need a PVR
i've been on fastfilms.co.uk looking at theirs, just wondereing if there are any others around?
this is theirs
£125
http://www.fastfilms.co.uk/mini-dvr1.php
£270
http://www.fastfilms.co.uk/dvx-h264-...o-recorder.php
£399
http://www.fastfilms.co.uk/HQR-1-dig...o-recorder.php
£450
http://www.fastfilms.co.uk/hqr-2-sol...o-recorder.php
Old Feb 28, 2009 | 04:23 PM
focusv8's Avatar
focusv8
Depends how much you want to pay;
http://www.rfconcepts.co.uk/mini_dvr.htm
http://www.henrys.co.uk/cctv/portabl...orecorders.htm
Old Feb 28, 2009 | 04:41 PM
Fil's Avatar
Fil
ELASTIC BAND
when i looked at this before people were using the arcos pvrs
Old Feb 28, 2009 | 04:43 PM
Spiky's Avatar
Spiky
only issue with those is they are HDD where as the ones i posted are solid state
Old Feb 28, 2009 | 05:25 PM
Fil's Avatar
Fil
ELASTIC BAND
archos do ones that use SD cards tho, 16gb costing under £20 so allways an option
Old Feb 28, 2009 | 07:30 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
YOu may have more luck searching for DVR's rather than PVR. DVR is typically what the device is called that does what you're after.
Old Mar 1, 2009 | 01:36 PM
foreigneRS's Avatar
foreigneRS
Testing the future
my archos 604 is good for in car, but shite for on bike. have tried numerous times to record track action and it just seems to suffer from vibration too much and always ends up with corrupt files, locked up or shut down
Old Mar 19, 2009 | 12:10 PM
foreigneRS's Avatar
foreigneRS
Testing the future
just got a used archos 405 off ebay that is solid state (records onto internal memory and SD card) that my exisiting bullet cam plugs into. will trial that out on the bike later, as well as an HD camcorder that records onto SD card that i can mount on the tank via a bracket on the fuel filler
Old Mar 19, 2009 | 12:13 PM
Spiky's Avatar
Spiky
cool
what size memory? and what size SD cards will it take?
Old Mar 19, 2009 | 12:31 PM
CraigoScott's Avatar
CraigoScott
spiky, i thought you were trying to LOSE weight off your car, not GAIN weight
Old Mar 19, 2009 | 12:32 PM
Spiky's Avatar
Spiky
bullet cam is lighter than a normal camera
Old Mar 19, 2009 | 12:35 PM
CraigoScott
i thought you would of thought of that!!
Old Mar 19, 2009 | 12:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
cool
2GB internal and can take up to 16GB cards apparently.
as an idea of size, video from a bullet cam of 13.5 minutes is approx only 275 MB so plenty for a trackday
Old Mar 19, 2009 | 12:59 PM
Spiky's Avatar
Spiky
cool
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
