Cossie Calipers???
Old Feb 27, 2009 | 10:50 PM
stevedb's Avatar
stevedb
Default Cossie Calipers???
Are Cossie 4 POT front calipers much better than the Cossie 2 POT front calipers? I was wondering if i should upgrade but if theres not much difference between them then i just stick to what ive got.
Thanks
Steve.
Old Feb 27, 2009 | 11:01 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
dont think much differesnces in calipers its getting them to fit as discs are different i don't think 4 pot cossie ones fit properly without some sort of mod mate hope this helps
Old Feb 27, 2009 | 11:36 PM
stevedb's Avatar
stevedb
I thought because they where 4 POTS they would perform alot better.
Old Feb 28, 2009 | 12:27 AM
taz1787's Avatar
taz1787
depending on what bhp and how quick your going it will be an improvement but not as big as a competion 4 pot calipers etc and 90% of the time you won't see a great difference as your not going quick enough etc just imo mind
Old Feb 28, 2009 | 11:48 AM
boost monster's Avatar
boost monster
I have 4 pots on mine but i think the 4WD calipers are easier to fit and just as good if not better.
Old Feb 28, 2009 | 12:16 PM
JamboRS's Avatar
JamboRS
focus rs 1672
whats 2pots??
4 pots if workin correctly are far superior to the 4wd brakes
Old Feb 28, 2009 | 12:44 PM
Kevin_Mc's Avatar
Kevin_Mc
Originally Posted by JamboRST
whats 2pots??
those ones i bought off you are shit hot
Old Feb 28, 2009 | 01:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I had heard that the S2 master cylinder doesnt have the girth to run Cossie 4 pots properly, and so single pots (4wd) are preffered.
Just what i was told though, no actual experience with them myself.
Old Feb 28, 2009 | 03:02 PM
B16CVH's Avatar
B16CVH
4wd ones all day long
Old Feb 28, 2009 | 03:45 PM
boost monster
Originally Posted by Karlos G
I had heard that the S2 master cylinder doesnt have the girth to run Cossie 4 pots properly, and so 2 pots (4wd) are preffered.
There is an increase in pedal travel but mine seem to work well.
Old Feb 28, 2009 | 04:29 PM
addiction's Avatar
addiction
4wd calipers are single pot!!!!
Old Feb 28, 2009 | 06:15 PM
Pat's Avatar
Pat
Well i just fitted 4 pots to mine.. there is def an increase in pedal travel.. very spongey at present but got new pads all round.. seem to be getting better all the time..
Old Mar 1, 2009 | 09:05 PM
JamboRS's Avatar
JamboRS
focus rs 1672
never had any trouble stoppin mine with an s2 master cylinder,could get it sittin on its nose no bother
they werent when i bought them mate,3 of the 4 pistons on both were seized/part seized,i bought a seal kit and reconned them myself,piece of piss to do,so if u get trouble with them stickin again its defo worth doing
Old Mar 1, 2009 | 09:32 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I've got cossie single pot up front with S2 discs and the spacer brackets, and cossie 2wd on the rear, anyone know how good they will work? told they'll be pretty good.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
