boost levels
Old Feb 27, 2009 | 12:55 PM
orion88's Avatar
orion88
Default boost levels
so what u all runing boost wise and how is ur engine adapted to not explode
thinkin the higher enders here running 20psi as i wanna run that much but i dnt wanna go pop
Old Feb 27, 2009 | 01:03 PM
robj20's Avatar
robj20
18psi for me at the minute.
Old Feb 27, 2009 | 01:15 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Build a high quality engine with very good parts. Do not skimp on the cost and its not hard imho
Simply don't have champagne ideas and lemonade pocket.
My CVH which runs 22 psi was not cheap to do, how fast can you afford to go?
Old Feb 27, 2009 | 02:06 PM
orion88's Avatar
orion88
honestly its a good engine the pistons are good i did the hewad lastweek all the valves are spot on cams good not a bit of smoke from it all new plugs aswell so its a tidy engine however i dnt wanna start blowing heads and damaging pistons by running it on 20
Old Feb 27, 2009 | 04:21 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
run 20psi on a std bottom end for the past 8 years,never had a problem!
Old Feb 27, 2009 | 04:33 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
I doubt you can reach the block internals limits by raising boost on a completely std engine with std turbo. Even if you run silly boost the head probably wouldn't flow enough to develop "dangerous" cylinder pressures.
Only way to kill it is detonation, IMO.
Old Feb 27, 2009 | 04:49 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Exactly right Peter the little T3 will be screaming its guts out producing nothing more than really high ACT's.
Take it to your nearest reputable tuner and get them to set it up for as much as your specification can produce!
Old Feb 27, 2009 | 05:13 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Give it me for a day and ill blow it up boost or no boost ill bet yas!
Old Feb 27, 2009 | 05:18 PM
crazycage's Avatar
crazycage
you think it would last THAT long lol
Old Feb 27, 2009 | 05:21 PM
orion_crazy_carl
orion=mini saff
lol,i look on it like, its gonna break, might as well do it properly!
Old Mar 2, 2009 | 09:08 AM
orion88's Avatar
orion88
i know ur idea of blowing stuff up carl
think i migh go for 15 boost and get it tuned to that spec
just curious to see if any ones running 25 or more
Old Mar 2, 2009 | 09:27 AM
daviddunlop83's Avatar
daviddunlop83
The norris motorsport stage 7 engine my friend has holds about 27psi but it is all down to how much you want to spend.
Old Mar 2, 2009 | 09:28 AM
rstel1's Avatar
rstel1
I'd stick to a safe setup mate that way you can drive the car better and harder knowing the engine will take the abuse.
But i all depends on your engine spec
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
