rs2 overheating
Old Feb 26, 2009 | 09:56 PM
triplej's Avatar
triplej
Default rs2 overheating
Need some help .What temperature does fan kick in when car is ticking over for about 10mins?gauge reading is half way...blowers fine but tank boils up and spills...could it be water pump I also find it difficult to start when warm and idle speed hard to set
Old Feb 27, 2009 | 07:56 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Hmmm..... sounds like head gasket mate, water should never boil up and spill out.
Old Feb 27, 2009 | 08:48 PM
triplej's Avatar
triplej
Hope not i replaced head gasket with a steel type sport material....
Old Feb 27, 2009 | 08:51 PM
triplej's Avatar
triplej
Found fan running slow...if you tap it it kicks in a little faster....might change fan first,thanks for your help!!
Old Feb 28, 2009 | 08:09 AM
dazrsturbo's Avatar
dazrsturbo
you could have some blocked pipes somewhere mate??? best to drain and flush the system out with a hose to push and gunk that may be in there out, i had a blockage where the water runs into the heater system inside the car.. unblocked it and never leaked/ boiled again
Old Feb 28, 2009 | 12:01 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
Hi matey
As Daz posted above check the cooling system has enough anti freeze in it, this should be diluted with water so it’s a 50 – 50 mixture. Drain it once a year and flush the radiator out, to remove any rubbish or blocks in the radiator.
Before you start pulling it apart LOL, look at the simple things first then
work from there.
1) Check the water thermostat in the cylinder head. Buy a new kit and change it over. But test it in a pan of hot water first to make sure it opens up when the water is hot and that it closes when the water cools down.
2) Check that the fan switch is functioning as they are prone for failure.
3) Another thing to check is that the header tank is OK and not cracked, and that the cap seals properly. In the past my header tank split and hot water leaked everywhere, not what you need when you are driving along. My car now has an alloy one on the car. Plastic header tanks are still available from Ford if you need one.
4) If you don’t like the idea of your car sitting in traffic and waiting for the fan to come on then do what I did. Connect the fan to a manual switch inside the car so you can control when the fan comes on and goes off, but the car can still switch it on in case you forget. Only takes about an hour to fit.
cheeRS
Chris
Old Mar 1, 2009 | 05:26 AM
triplej's Avatar
triplej
Default rs overheat
Originally Posted by Kristoff28
Hi matey
work from there.
cheeRS
Chris
Thanks lads for all the help i will get stuck into draining it today and keep you updated....great help on this site
Old Mar 1, 2009 | 05:27 AM
triplej's Avatar
triplej
CHEERS jjj.........will keep you posted
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
johncossie
Dec 19, 2005 11:36 AM
Cam
Jul 12, 2005 12:58 PM
BigDave
Ford Classics & Vintage
Dec 5, 2003 01:36 PM
