Any Peugeot technicians about?
Old Feb 26, 2009 | 08:41 PM
Danster76's Avatar
Danster76
Default Any Peugeot technicians about?
Need some advice.
Old Feb 26, 2009 | 08:42 PM
MAD EVO 4's Avatar
MAD EVO 4
what do you need to know ?
Old Feb 26, 2009 | 09:02 PM
Rossco's Avatar
Rossco
My guess is a wiring fault.
Old Feb 26, 2009 | 09:08 PM
Danster76's Avatar
Danster76
206 2.0cc (petrol) anti pollution fault.
Central display and mgt light on.
Car doesn;t drive any differently, no lumpyness, no power loss etc just dash lights.
So far have changed cat and Lambda sensor nearest the engine (up stream?). Cleared the codes and stays off for 100 or so miles then pops back on. HAVE to get it fixed. Searched about the forums and can't find true fix. Some peeps have lumpy and powerloss and seems to be coil pack or cam followers to fix?
Anyone know the answer to this one please
Old Feb 26, 2009 | 09:27 PM
AlexF's Avatar
AlexF
Common on these...
But a common cure - cam sensor, o2 sensors and so on.
Old Feb 26, 2009 | 09:30 PM
westus1's Avatar
westus1
was a dodgy fuel filter on mine, changed that and never done it again
Old Feb 26, 2009 | 09:32 PM
Danster76's Avatar
Danster76
Yes I've done one O2 sensor so far. £120 a pop if i'm barking up the wrong tree can someone let me know before I waste more money on this bag'o'shite motor cam sensors not one i've thought or heard about. Do you speak from exprience?
Old Feb 26, 2009 | 09:34 PM
Danster76's Avatar
Danster76
Fuel filters easy enough and cheap enough to try. She's already had a big can of redex as cheap fuel is meant to set them off....
Old Feb 26, 2009 | 10:50 PM
Rax's Avatar
Rax
Have a look on http://www.peugeotcentral.co.uk/ I used to be on there sometimes with our 207GT with similar problems.
Old Feb 27, 2009 | 07:01 AM
Rossco's Avatar
Rossco
I had the anti polluition come on a few times when I had a 307 HDI and you gave it a good hiding.
Found the best fix was just to drive it slower
Old Feb 27, 2009 | 11:20 AM
AlexF's Avatar
AlexF
Cam sensors allow cars to run squential injection - thats good for emissions...
If the ECU dectect the cam sensor is faulty it wont be able to run in that mode.
Alex
Old Mar 22, 2009 | 04:45 PM
billykeren's Avatar
billykeren
This is a common problem for the Peugeot 206 2009.
Old Mar 22, 2009 | 06:08 PM
as355f1's Avatar
as355f1
quite possibly the dreaded hydraulic lifter problem only affects the 2.0 engines, only way to fix is replace all 20 lifters, there was a design fault in some of them and it causes the oil to drain over night causing a slight misfire in the mornings bringing on the anti pollution light and managment light.
Mile30
69
May 13, 2017 08:44 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
matts1
Oct 19, 2005 08:49 PM
Shell
18
Jul 24, 2005 05:32 PM
