APs on a 4x4 sapph
Old Feb 26, 2009 | 08:38 PM
Trist's Avatar
Trist
Default APs on a 4x4 sapph
my father in law has a 4x4 sapph and is after a set of brakes as he only uses it on track days, he has found some 362 x 32 Vented AP Discs + AP 6 Pot Front Caliper Kit and 330 x 28 Vented AP Discs + AP 4 Pot Rear Caliper Kit
Reyland Machined Aluminium Mounting Brackets & Bells with bolts
Ferodo Brake Pads
will they fit and does he have to use 18s?
also how can he connect the hanbrake?
Old Feb 26, 2009 | 08:42 PM
charlie luciano's Avatar
charlie luciano
4x4 saphs are a pain in the harris when it comes to fitting big brakes, as long as he has the right spec alloy with correct offset they will go in
Luciano
Old Feb 26, 2009 | 08:53 PM
Trist's Avatar
Trist
Is that an 18inch wheel? do you know what off set?
Old Feb 26, 2009 | 08:58 PM
col cos1's Avatar
col cos1
my saph had exact same front brakes with 18in comps,et25 offset
ive put them on 3 door now and trimming is required up front,but were fine on 4x4 saph just the arches were rolled
Old Feb 26, 2009 | 09:03 PM
Trist's Avatar
Trist
nice one thanks mate he has just got some GAZ coilovers. what about handbrake caliper, my mate used to run RS200 caliper. is there another way?
Old Feb 26, 2009 | 09:04 PM
col cos1's Avatar
col cos1
if puting ap 4s on back you defo need to add another standard caliper for mot purposes i think
Old Feb 26, 2009 | 09:07 PM
Twellsie's Avatar
Twellsie
et25? i had 8 x 16 et25 wheels on mine and they where shite!
Old Feb 26, 2009 | 11:46 PM
NUTS RuS's Avatar
NUTS RuS
Track car might not need MOT
Old Feb 27, 2009 | 09:50 AM
Trist's Avatar
Trist
he does drive it to and from as we are from the isle of wight to take truck and trailor on the boat is silly money for a day out.
Old Mar 2, 2009 | 12:20 PM
Trist's Avatar
Trist
Any more info on wheels needed and about a handbrake?
Old Mar 2, 2009 | 01:08 PM
dojj's Avatar
dojj
Resident Wrestling Legend
spot caliper for the handbrake
martin @ reyland for the wheel offset
Old Mar 2, 2009 | 01:55 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
8x18 ET35 Comp Mo 6 spokes will clear a MAX of 362 on Sapphire 4x4 .
Regarding handbrake, Martin @ Reyland does a conversion that uses the existing standard callipers as just the handbrake . Consists of brackets and cut down pads (which have to have material ground off to suit the additional width of the brake discs).
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
