mk3 conversion
Old Feb 26, 2009 | 11:10 AM
orion88's Avatar
orion88
Default mk3 conversion
hey folks thinking of turning the mk4 estate to a mk3
do i need to swop the wings and slampanel or is it the whole front end that needs changing the whole slam panel not just the top bit?
ive heard the cross over models mine being a c reg estate didnt need the panel changing just the wing
is this true?
and do the mk3 rear bumpers need to be modded to fit aswell or isthat a simple bolt on jobby?
Old Feb 26, 2009 | 11:15 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
scuttle panel ,wings, bonnet and front panel.and rear panel.as far as i no mate.
Old Feb 26, 2009 | 11:54 AM
orion88's Avatar
orion88
scuttle panel where the wipers go?why do u need to swop that then?
and is the rear bumper a straight swop or do i need to swop the rear panel and why?its an estate so surely the one on it will be fine?
Old Feb 26, 2009 | 03:01 PM
cabrst's Avatar
cabrst
becouse theres a diffrent in the bonnet so the egde won't line up....
as for rear panel i can't remeber the estate but if you look on a mk3 vs a mk4 you can see that the rear panel on the mk3 goes down to the wing buttom where on the mk4 its cut higher up....
mk3
mk4
Old Feb 26, 2009 | 03:14 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
not sure on estate rear panels but looking at the mk3 above the mk4 bumpers should bolt straight on and vica versa but front end it is
both wings
scutle
full front panel including bottom bit
bonnet
grill
indicators
headlights
and if you wanna do a proper job so it looks like true mk3 bulkhead and inner wings
if doing innner wings then you will need a mk3 top engine mount if not and going to for a mk3 engine then don't forget to get a mk4 top engine mount as they are different
hope this helps
depends really how far your going with it thanx alain
Old Feb 26, 2009 | 03:41 PM
orion88's Avatar
orion88
lol ok all very usefull can anyone suggest whewre to get a scuttle panel from?
ive heard for dnt make them anymore
so the mk3 scuttle panel is smaller than the mk4?
and its the panel where the windscreen wipers sit?
seems odd ford did that
then again they do make some weird revisions
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
