17" softspokes
Old Feb 25, 2009 | 11:34 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Default 17" softspokes
Hi guys whats best suspension setup to have to fit the 17" softspoke alloys?I currently have Apex springs and dampers,the springs i think are -40mm and ive tried a 17" alloy which was on the car with standard ride height and didnt rub,now as soon as jack is lowered the wheel is fouling the arch.Would standard springs fit in the Apex dampers ok? and would it look good at standard height with the 17" wheels?
Old Feb 25, 2009 | 11:52 PM
RSmark84's Avatar
RSmark84
most people get their arches rolled.
Old Feb 26, 2009 | 06:01 PM
project rs's Avatar
project rs
i've got mine at standard height at back and looks ok could do with being 10mm lower but no one does a 10 mm lowering spring that i know of and the front is about 15 mm lower than standard and looks great and no rubbing anywhere even with 4 people in car with the diamond cut version of yours with 205/40 tyres
Old Feb 26, 2009 | 08:45 PM
martinmilne's Avatar
martinmilne
i got softlines 17" on mine its got g max shocks and 30mm lowering springs and no problems
Old Feb 26, 2009 | 11:31 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Cheers for replys guys,will i be ok getting some -20mm springs and fitting them in my apex dampers?
Old Feb 27, 2009 | 02:45 PM
becca s2rs's Avatar
becca s2rs
Ive got koni's and 35mm lowering springs only rubbed slightly with 5 people in car and hitting the london bumps!! did rear disc conversion and had to roll arches i have diamond cut rs7s good luck
Mungus
23
Jan 15, 2012 09:27 PM
turbocat
Alloy wheels and ICE for sale
Sep 12, 2011 07:54 PM
BIG MULL
25
May 16, 2011 06:12 PM
s1 dean
Jun 21, 2007 05:10 PM
