OFAB ECU
Old Feb 25, 2009 | 09:29 PM
RS 5tu's Avatar
RS 5tu
Default OFAB ECU
What power range will they run?
701s are 15.8 OHM`s But could you use a lower or higher OHM injector
say between 14.0 - 17.0 OHM`s
Old Feb 25, 2009 | 09:37 PM
©hatter Box's Avatar
©hatter Box
delta green are the next one up. delta beiges are bigger again
Old Feb 25, 2009 | 09:48 PM
RS 5tu's Avatar
RS 5tu
yeh but what about different injectors? You can get better injectors than 701s and cheaper but run at slightly different OHM`s
Old Feb 25, 2009 | 10:08 PM
©hatter Box
they are diffrent injectors. that what grove would use if they want bigger then 701s i had the green in my old 2.1zvh then moved up to beiges when the t34 was fitted.
i take stu maps your car i would ask him.
Old Feb 25, 2009 | 10:10 PM
Smartdj.'s Avatar
Smartdj.
are 701 beiges the biggest injectors for the rst..?
Old Feb 25, 2009 | 10:16 PM
©hatter Box
your cant use 701s ones on and rst unless you have efi.
RS 5tu's Avatar
RS 5tu
No. And tbh there quite poor at only 226cc
Old Feb 25, 2009 | 10:50 PM
Smartdj.'s Avatar
Smartdj.
ohh i was always led to believe they were the biggest
Old Feb 25, 2009 | 11:10 PM
©hatter Box
your lucky if they can flow 210bhp if that out of them std blue about 180 mark
Old Feb 26, 2009 | 11:40 AM
RS 5tu's Avatar
RS 5tu
If you want a decent power engine imo aftermarket management is the best option you can run high or low impedance injectors giving you a wider selection. And as chatter box says 210 is the limit one 701s you can get better ones for less money like saab 250cc ones for £20-50 but they run a slightley different OHM`s so dont know if they would work on ofab/ofac ecus
Old Feb 26, 2009 | 12:32 PM
ECU Monitor Enthusiast
There is no power limit if its live mapped
Old Feb 26, 2009 | 12:43 PM
RS 5tu's Avatar
RS 5tu
I am deffo going aftermarket. It may seem cheaper to go Cossie/FRST but by the time you done inc a live map i would say its about the same maybe cheaper.
Old Feb 26, 2009 | 12:45 PM
RS 5tu,
The OFAB ecu is flaky at the best of times so a wise idea IMO
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
