assistance from excell spreadsheet experts please
not being a master computer whizz, i have so far only been putting in manual figures but i was wondering if there was a way for the computer to do it for me
the problems are as follows:
i have set the conditioning format of the spreadsheet to put a "H" if someone is on holiday, a "S" if they are off sick and an "X" if they are not working for any other reason
these get tallied up and give you an end of the year figure for all sorts of stuff and are updated in a different spreadsheet that i don't have access to alter but can view so that i can make things right in there, it's too complicated for me to explain but it all works
what i need to do is to make sure that if i put "H" into the spreadsheet, not only does it tally up elsewhere, it also adds 9.5 (the hours that they get paid for normally) onto some other bit of the spreadsheet, rather than tally up the holidays acrued over the months/year and then start adding them up into the totals column
firstly, is this possible?
secondly, can someone show me how to do it if the answer to question 1 is yes?
thank you
thank you
that's the sort of thing it gets confusing with
i can do the nice simple stuff like l;earn what does what in one cell to another and then copy it for other cells, but it's the original getin i to work that does my tits in
for example, i have no idea what "if()" means althuogh i will hazard a guess that it may me that if there is a certain letter in the ( and the ) then a certain formula will be going on, but can you do that multiple times?
conditioning format only allowes me to do it 3 times for the sheet otherwise i would have used that
In the cell you want the 9.5hrs to appear, I would use a function something like:
=if(or(A1="H",A1="S",A1="X"),9.5,"")
Where A1 is the cell you are testing.
The IF statement says if the following statement is true (the or statement in this case), then set the value of this cell to 9.5, otherwise set it blank.
Another way of explaining it is: If any one of the conditions in the or statement is true then the value will be 9.5, otherwise blank.
PS you need the equals at the beginning of the function so Excel will recognise it as a function.
HTH
Neil.
HTH
Neil.
the help facility in excel is actually quite good, its how i learnt - give that a go. Type in "if statement" into the search top right of excel and it will give you examples
if you want to apply it to a range of cells then you simply say e.g. A2:A2000 (that means it will apply the formula to all data in cells A2 -> A2000
make sense?
Matt
That won't work in this case lads.
Dojj, you need the formula in each cell, so copy and paste it. Excel will update the cells the formula points to itself.
Start with just one cell first though so you know you've got the formula right.
You can do this between workbooks but it's a little more complicated. If you need to do this I can show you how though.
DavidK
Sep 27, 2015 02:55 PM
