Smart ForTwo Hayabusa Project - Update 04/05/2015
Old Feb 25, 2009 | 10:53 AM
42Haya's Avatar
42Haya
Default Smart ForTwo Hayabusa Project - Update 04/05/2015
Hey Everyone,
Update - 04/05/2015 - See Page 3!
Re-fitting Clutch.
-42Haya
Old Feb 25, 2009 | 11:25 AM
CraigoScott's Avatar
CraigoScott
we need pictures, badly
Old Feb 25, 2009 | 11:37 AM
Ed1's Avatar
Ed1
Pics here!
https://passionford.com/forum/general-car-related-discussion/286096-hello-new-user.html
Old Feb 25, 2009 | 07:57 PM
BIG.GEOFF.H's Avatar
BIG.GEOFF.H
cool project that will be fun been looking at doin g somthing like this hurry up bricky and get my garage up good luck pal
Old Feb 28, 2009 | 08:02 PM
42Haya's Avatar
42Haya
Update - 28/02/2009
Hey Guys, an update for you all.
I've taken apart both driveshafts and cleaned everything up. I've even taken the Lobro fittings apart and soaked them I've got new boots and grease on the way!
I have also got the rear hubs apart, i need to press the bearings out now (tips anyone?), new bearings will be ordered tommorow.
Once the bearings are out then i'm getting everything sand blasted and powder coated, the custom rear uprights will be ordered early week too.
Tommorow i'm taking one of the front hubs off, measurements are then going to be taken so my custom front hubs can be made (Ford PCD instead of Smart PCD). These shouldn't take too long to make so hopefully i'll have some pictures soon.
Two of the driveshaft bolts were a nightmare to get out (the last two as well!), i've ordered 50 Socket Cap version so i'll have a few spare for when the diff is ordered.
Anyway, i've got a few pictures also.
I'll grab some more photo's tommorow!
Old Feb 28, 2009 | 08:41 PM
jammerrs's Avatar
jammerrs
sounds good
Old Mar 1, 2009 | 03:02 PM
42Haya's Avatar
42Haya
Update - 28/02/2009
Afternoon all, not much hands on work today but alot of design work is about to start.
I've taken off the original ForTwo front hubs, as i've mentioned before these are going to be remade but with Ford wheel fitment (4x108).
The reason for this obviously that i won't be able to get any decent and matched front and rear wheels.
This will mean though i'll be using Ford Sierra or similar front calipers and discs, i'll have to get these to fit using custom bits when it comes to it but for the moment i didn't want to spend too much time at the front when the rear needs all the thought and work initially!
Here's a few pictures to explain what i've been talking about.
Original Smart Fortwo front Hub
Note the ABS ring attached on the opposite side
Left: Fortwo front hub, Right: Ford Sierra Cosworth 4x4 Rear Hub
The difference between the hubs is only a few millimeters so it won't cause too much of a problem, the main concerns is obviously getting the ABS ring in the right place on the new hub, and making sure the hub center is correct so that Ford Wheels will fit on perfectly.
Should have some drawings of the new hubs later
Old Mar 17, 2009 | 09:14 AM
42Haya's Avatar
42Haya
Update - 17/03/2009
I picked this up yesterday..
This should certainly do the job!
I've also been working on my welding skills and can say its definitely something everyone should try! Very easy once the welding kit is setup for the type and thickness of the metal .
More updates soon.
David
Old Mar 20, 2009 | 12:41 PM
42Haya's Avatar
42Haya
Update - 20/03/2009
Everythings at the powdercoaters! Here's a before picture..
I'll take an 'after' picture once i get these back early next week.
I've also purchased some bearings to sit on either side of the diff, i'll be bending up the tubing previously purchased and welding together a rough design for the rear subframe.
To be continued..
Old Mar 20, 2009 | 12:47 PM
RS 5tu's Avatar
RS 5tu
what kind of performance figures would you see from one of these?
0-60?
0-100?
Old Mar 20, 2009 | 01:01 PM
42Haya's Avatar
42Haya
0-60?
0-100?
A standard Suzuki Hayabusa has the following statistics:
1/4 mile: 9.62 seconds @ 149.7 mph
0–60 mph: 2.60 seconds
0–180 mph: 15.9 seconds
With the addional weight (Hayabusa is around 230KG, SmartBusa will be about 600KG) but with the lowered gearing to our advantage. I would hope the 0.60 to be about 3.4 seconds.
The standard hayabusa does 90mph in 1st and 117mph in 2nd, so you can see how lowering the gearing will be to my advantage (i'd still like 60mph in 1st gear).
Obviously i won't know exactly how quick until the car is completed and i can run some real tests.
Old Mar 20, 2009 | 04:44 PM
Zetecfiesta's Avatar
Zetecfiesta
thats just nutty!
Old Mar 20, 2009 | 04:47 PM
doctor stavros's Avatar
doctor stavros
AMG C32
Thats gonna be an awesome set of figures. Roughly, how much is this all gonna cost, from the projects conception, to the finished article?
Old Mar 23, 2009 | 11:40 AM
Twellsie's Avatar
Twellsie
loving the idea of this
Old Mar 30, 2009 | 01:38 PM
42Haya's Avatar
42Haya
Update - 30/03/2009
Rear Calipers arrived today, HUGE! Should definitely stop the rear end no problem Will measure to see if they take Solid or Vented discs, either way they'll be more than enough to stop the rear end of a 600KG car.
Had word from the powder coaters mentioning they weren't too happy with how some of the parts came out, so getting them back tommorow.
David
Old Apr 2, 2009 | 07:59 AM
42Haya's Avatar
42Haya
Update - 02/04/2009
The parts are back from the powder coaters! I've just got to clean up a few threads and spines.
Before
After
The rear calipers have also arrived and i've ordered two rebuild kits, i've gone for the solid disk versions.
More updates soon..
Old Apr 2, 2009 | 08:11 AM
Twellsie's Avatar
Twellsie
would it not have been a good idea to mask all the bores, threads and splines?
Old Apr 2, 2009 | 08:21 AM
42Haya's Avatar
42Haya
I had the lobro joints masked but to be honest i wasn't sure on how thick the powder coat would be on the splines. Its not too much effort to whisk a dremal or similar accross the spines so i wasn't too fussed.. I'm pleased with the results though!
Old Apr 4, 2009 | 01:56 AM
oohogwash1's Avatar
oohogwash1
Keep up the good work, this car will be amazing....
Old Apr 4, 2009 | 03:53 AM
Arne's Avatar
Arne
Ill promise you. You gonna have a nightmare cleaning those parts. And the powdercoat will crack and it will very soon rust and look like shit. But best of luck anyway. Cool project.
Old Apr 5, 2009 | 12:21 AM
oohogwash1's Avatar
oohogwash1
Whilst it would have been easier to mask, it is what it is and your steps forward make sense. I know what is like to take a step forward then find that an earlier step would have made life easier.
I do my own powder coating, in case you get more done here is how I mask of bits...
I use aluminium foil for most bits, cheap and easy to use. I often remove the bigger aluminium bits prior to curing. For more intricate bits I have heat proof tape that will not effect the curing. In your case I would get your guy to do his sand blasting the return for masking.
On the cracking, I bet you have thought of this already, you might find that using a fine dremel grinder or similar tip to make a sharp clean edge first up and taking time move out from the edge before you get a bigger tip would be ok. I would say the most important bit is to avoid fracturing the coating. Given that it tends to bond I think it will work just takes time.
On the rusting the shafts are bright steel so I think it wont be too bad, I put CRC or similar stuff on the metal and use that to avoid rust. On the castings I think most of your clean up is inside and will be covered with grease.
Put up some pics when you get em cleaned off. They will look awesome im sure.
If you do find its taking to long, consider getting another set and mask them up, cleaning off the parts with sand blasting to recoat is common but might be risky due to risk of damaging the surface. I bet your powder coater used sand blasting prior to coating to get a clean surface. Check with him as you might find that you can mask of what you want to keep coated and sand blast the rest off.
Also have you checked on effect of curing in relation to effecting the heat curing of the axles... exposure at that high temp might effect their strength. I have not elected to powder coat my axles for fear of effecting strength, if you found some info on that I would be interested.
Old Apr 5, 2009 | 10:38 AM
42Haya's Avatar
42Haya
I managed to get all the powder coating off the splines yesterday, they look amazing. Will have the driveshafts completely built up by the end of today.
Thanks for the support guys..
David
Old Apr 5, 2009 | 10:53 AM
Oranoco's Avatar
Oranoco
This whole project is making me grin. It has oodles of that "What the Fuck!!!" factor and the potential for upsetting far posher cars in something that looks like a rollerskate is fantastic.
Hats off to you sir, I'm loving it
Old Apr 5, 2009 | 03:21 PM
42Haya's Avatar
42Haya
Many thanks and much appreciated, your description hit the nail on the head when it comes to what this project is aimed to do
Old Apr 5, 2009 | 11:15 PM
42Haya's Avatar
42Haya
Default Smart ForTwo Hayabusa Project - Update 06-04-2009
Update 06-04-2009
..and here's one I made earlier
Complete Shaft
New CV Boots
Quaife Lobro Joints
Cap Head Bolts
I'm missing a circlip from the inside of the other drive shaft, so as soon as i source another i can get the other one together
The caliper seal/o-ring kit should be here tomorrow. I'll get these cleaned up, painted and sealed this week.
More news soon..
Old Apr 5, 2009 | 11:19 PM
jeans43's Avatar
jeans43
humm looks like it will be Fookin ace when its done keep updates n pics coming
Old Apr 6, 2009 | 07:30 AM
Little-AL's Avatar
Little-AL
All this time and just a set of shfts have been put together?
Come on maaaaaaaaan.....start cutting holes in it or something!
Old Apr 6, 2009 | 07:54 AM
42Haya's Avatar
42Haya
I know i know! We've had a few let downs with the pipe bender which has really slowed us down but we can't start the subframe until we have the driveshafts built up
It'll soon take off once we get bending and welding
Old Apr 15, 2009 | 08:19 AM
natehall's Avatar
natehall
wow!
This is simply going to be mental!
Old Apr 21, 2009 | 02:28 PM
42Haya's Avatar
42Haya
Update - 21/04/2009
Not much to report but a minor update. Wheel bearings have arrived and have been pressed into the hubs. This morning i sent off the cheque for the kit-car rear uprights.
Soon as these arrive the rear subframe is getting built
Bit of slow progress but i can see alot getting done over the next month!
Old Apr 25, 2009 | 08:13 PM
42Haya's Avatar
42Haya
Update - 25/04/2009
Lots of progress today!
Making some final decisions on wishbone design, calipers are half way being refurbed. The colour of the calipers look simply amazing! I'll post up some pics of them once they've had a few more coats
Getting some inserts made for fixing the new subframe to the original mounting points. As soon as these are made its go go go!
Old Apr 25, 2009 | 09:43 PM
rallycross's Avatar
rallycross
wow you are a brave man, would love to have a go in this once you've got it finnished.
part of my job is buying/selling (used) smart for two's and when you hustle them along at a half decent pace (ie half what you'd be doing in a ka 1.3!) they are one of the worst handling cars I've ever driven, it will be interesting to see what you can do to get it to handle, stop and steer.
In many ways they are great, as in a great city car, but making one quick and handle is a big challenge good luck and keep us updated...
Old Apr 30, 2009 | 01:07 PM
gingerman's Avatar
gingerman
what a project lol
keep us posted
Old May 2, 2009 | 04:00 PM
42Haya's Avatar
42Haya
Update - 02/05/2009
First of my custom parts have been made! Some nice beefy subframe inserts to keep all the power bolted to the car.
Also these arrived, PTFE lined .. silky smooth
This should keep the back end in check! I'll be doing some subframe and arm work over this weekend. Should have something rolling very soon
Old May 2, 2009 | 06:18 PM
Rs Adz's Avatar
Rs Adz
this is a top project crazy but i bet it wil be more that worth it keep up the good work
Old May 14, 2009 | 09:53 AM
42Haya's Avatar
42Haya
Update - 14/05/2009
New subframe mounts in action
Old May 15, 2009 | 08:04 AM
You mad man.This is gonna be an animal.
Old May 18, 2009 | 09:57 AM
42Haya's Avatar
42Haya
Update - 18/05/2009
Prototype Subframe 1 Failed - We've started making a proper jig to hold it all in place so when welded it'll be alot more rigid! We had issues with the frame being stressed when bolted on to the car.
Atleast with a new jig we will have alot more room to play with compared to the previous method!
Old May 18, 2009 | 02:59 PM
Nightmare.I hope the jig works.
Old Jun 12, 2009 | 03:59 PM
3DOORCOZZIE's Avatar
3DOORCOZZIE
Default The best project ever
This sounds like a fantastic project and i am building one myself, brand new to building anything like this but have plenty of projects under my belt. would be very intrested in any info you have on the build IE. parts needed and were to find them, i have been on smartuki website and they sell everything you can ever need to build one including the rear subframe at the cost of £2500 but its only lists the gsx1000 k1,k2 etc engines not the 1300 fitment into the subframe, i guess you may have already seen there website with doing this type of project.. i will be very greatful for any help, info or anything you may think you can help me with in the building of the most fun i have ever seen on you tube Many thanks Cliff
