cossie management question
Old Feb 22, 2009 | 07:56 PM
cressy's Avatar
cressy
Default cossie management question
i'v brought cossie management that has efi inlet manifold but i want to use my s1 plenum what do i need and were can i get it from.gary how is doing management for me can do the necessary mods but if i can buy the parts from somewhere it will save him some time and grief
Old Feb 22, 2009 | 08:59 PM
B16CVH's Avatar
B16CVH
I modified the bore where the injector sits then modified the fuel rail and has some mounts welded on so that it would bolt down and seal on the rubber seals.
Old Feb 22, 2009 | 09:09 PM
gus's Avatar
gus
same as above
i think the s1 inlet is the better option of the 2
for further improvements
Old Feb 22, 2009 | 09:16 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Can you not use the efi version from a FRST? that fits cossie bosch injectors & has a suitable fuel rail , just match the port to the head (think efi head has injector cutout on port in head) & sort the Throttle body.
Old Feb 23, 2009 | 06:23 AM
cressy's Avatar
cressy
thanks guy`s looks like the frst opition is the better route
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
BRAM
Sep 8, 2015 07:11 AM
