1900 cvh piston help and com pression
Old Feb 22, 2009 | 01:01 PM
g1234's Avatar
g1234
Default 1900 cvh piston help and com pression
hi all i have a 1900 cvh power engineering engine and recently had compression test and no 3 was down by half so took head off and checked valves and all ok then took no 3 piston out and cheched rings this may be a stupid queston but one of the rings is stuck in the piston and wont come out well not tried force but is this the cause of my compression loss
Old Feb 22, 2009 | 01:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Could be mate, in my experience they should move freely round the piston.
Old Feb 22, 2009 | 02:02 PM
g1234's Avatar
g1234
yea thats my thoughts they should move but this one is stuck in the groove
Old Feb 22, 2009 | 02:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I'd say that is your problem then.
Old Feb 22, 2009 | 05:07 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Hows it stuck? seized or melted to the piston?
Old Feb 22, 2009 | 06:14 PM
g1234's Avatar
g1234
like its siezed in and only on 1 piston too
Old Feb 22, 2009 | 09:01 PM
B16CVH's Avatar
B16CVH
if it is stuck, this will hold it back from the wall of the bore resulting in a gap being created. Could be possible overboost where the pressure has forced the alloy of the piston down causing it to squash the ring.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
sridgett
13
Sep 27, 2015 06:03 PM
