RS TURBO S2 Actuators
Old Nov 27, 2004 | 02:01 PM
K18NEO's Avatar
K18NEO
Default RS TURBO S2 Actuators
Where can you get the standard brand new ones from? Internet sites and local places to walk in and buy on cause pj motorsport dont do them anymore. Im in west midlands!
Old Nov 27, 2004 | 02:58 PM
Paddy's Avatar
Paddy
Legend
what do you want a standard one for ya big girl?
Old Nov 27, 2004 | 03:07 PM
rabmc's Avatar
rabmc
-31 is the one u want
Old Nov 27, 2004 | 03:28 PM
dave cos4x4's Avatar
dave cos4x4
Can you not order one from Woodford for example.
Plenty of suppliers of them in the mags etc...
Dave.
Old Nov 27, 2004 | 03:45 PM
ballin's Avatar
ballin
ive got a brand new one in box, what boost you running?
if hes running standard no point in getting a -31 really is there
Old Nov 27, 2004 | 03:51 PM
rabmc's Avatar
rabmc
Imagine thats not much price difference between standard and a -31 so may as well buy the -31 coz in the long run it will be able to handle increase in boost if needed plus will do the job of running standard boost just now(if he is runnin standard)
Old Nov 27, 2004 | 04:19 PM
flashpoint's Avatar
flashpoint
Steve
Old Nov 27, 2004 | 04:56 PM
K18NEO's Avatar
K18NEO
GUYS!! I went to buy that today, but the bloke at PJ's, said that it would be pointless because they run hi 16's 20s and go up to 30psi, as mine is standard and hasnt had the ecu chipped, i need a standard one for now. If i was to get the -31, the ecu would step in every time i plant it and cut it out, which means it wouldnt be running proberly. Can i just fit the cossie one and hope for the best?
I need help guys, im getting told one thing and another by others!
Old Nov 27, 2004 | 04:59 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
i got a standard car, bar a GRS cooler and K'n'N , and run a -31 on 15psi, run fine too
Get a -31 and get it set up
Old Nov 27, 2004 | 05:01 PM
K18NEO's Avatar
K18NEO
really? i dont want any more problems cuz at the moment, its running 6 psi max!! it is the actuator, so even a standard one would give me 10psi!
Old Nov 27, 2004 | 05:06 PM
Charlie Chalk
Unknown.
is your engine standard? what problems will you get??
from what i know if you fit a -31 you wont have many problems, so long as your car is set up right by a good tuner there wont be problems. my engine was fine before hand, but ive taken it off road now for a big bottom end rebuild
Old Nov 27, 2004 | 05:11 PM
K18NEO's Avatar
K18NEO
So what psi with the boost controller right down, will it be running standard with the -31? Because ive had enough problems in the past, as its a convertion from a 1.4, to an rs in my cabbie, i dont want any more problems, Hense why i want to get the standard one and be done with it!!
WIll it cut it out if i have one? Will i pop the engine?
Old Nov 27, 2004 | 05:16 PM
Charlie Chalk
Unknown.
"boost controller" being a Bleed valve , you can have it set at what ever boot you like,I would get it set to peak @ 15psi and hold about 12psi on your engine, the chance of popping is very slim imo, as i said get it set up by a good tuner and wont have any problems
Old Nov 27, 2004 | 05:18 PM
K18NEO's Avatar
K18NEO
thanks mate!!! will do that
Old Nov 27, 2004 | 05:19 PM
Charlie Chalk
Unknown.
but if you have a bleed valve ither take it off, or turn it right down
Old Nov 27, 2004 | 05:21 PM
K18NEO's Avatar
K18NEO
right down seems a good idea LOL
thanks for your help !!
Old Nov 27, 2004 | 05:25 PM
Charlie Chalk
Unknown.
NP
Old Nov 27, 2004 | 06:00 PM
ballin's Avatar
ballin
you can run std boost on a -31 no probs.
you wont be able to hit 15psi and hold 12 tho cos you say its not chipped....so your looking at 10psi tops! get a -31 by all means if you're planning on uprating, but if not then save the money and go std!
Old Nov 27, 2004 | 06:03 PM
K18NEO's Avatar
K18NEO
Oh im planning on uprating for sure, just wanted no hassle!! I will buy it asap and get it professionally set up!
Old Nov 27, 2004 | 06:25 PM
The Sludge's Avatar
The Sludge
garibaldi
you wil lbe hard pressed to find anyone in midlands to supply an actuator. Surprised Pj aintgot one. You speak to Jamie by any chance?
Old Nov 28, 2004 | 02:52 PM
K18NEO's Avatar
K18NEO
-31 are supplied by pj's mate! Dont think ill go for the standard now. In the long run, will be pointless!
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
