Saf cossy courtesy lamps faulty, any ideas?
Old Feb 21, 2004 | 02:38 PM
plater's Avatar
plater
Default Saf cossy courtesy lamps faulty, any ideas?
Car has been garaged over the winter and has developed a fault with the interior courtesy lamps, basically the two lamps located in the drivers and passengers footwell , which are supposed to switch off 10 seconds or so after the car is locked, are staying on all the time and consequently have drained the battery. I have removed the bulbs which solves the battery drain problem for the moment but would like to have the problem fixed properly. Does anyone have any ideas why the lamps are staying on and how i go about fixing things.
Old Mar 1, 2004 | 09:17 PM
at an edjicated guess i would say that they will be controlled by something like a relay somewhere. find a wiring diagram and have a look. If it is a relay give it a tap see if that works if not replace it, i could be completely wrong but being an electrician i am pretty confident
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Rizlablue
Sep 6, 2015 09:58 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
