Xr2 rebuild and mods (revised)
About 4 months ago.i bought this 2 owner car ,totally original, never kept in a garage , from sunny scotland...51,000 original milage backed up with full history ford mostly.
Its interior,plastics and engine,etc, are spotless i knew when i bought it it needed a fair bit of work but it wasnt until it was stripped that we realised the extent of the rot..
Iam doing most of the work at my pals body shop ,so hence the progress is not always as quick as i,d like as i have to fit in around his and my own work...
The plan is, standard to look at ( ford spec paint and striping) but with some performance upgrades , without spoiling its original design.. I look forward to any comments..or advice fellow members can offer
Iam not doing anything that extreme , just planning full shell rebuild,poly bushing,goodridge hoses,4 branch& system,performance head and kent cam,twin 40 dcnf downdraught carbs,uprated brakes etc.
been doing the engine this week..the carb fuel pipes are to be changed though..and done properly
my garage might look messy but the build was immaculatly done,
thanks for the positive comments,,all the welding is now complete ,as is the l.s.d gearbox,my other wheels and the engine....
its the filling and priming next.
I,ve got a brand new bonet and tailgate also,the ownly thing i may still need is a mint drivers door- if anyone has one locally that would be a help
i,ll post more pics of the progress later
was that the one that was on pistonheads in think it was edinburgh ?
a tried phoning him but he never answered the phone , thank fook thats needing alot of work , al keep an eye on the resto post , am just about finished my resto on my xr2 should be out next week all going well .
Yes its the one off pistonheads,,,it was worth the money all day for the good bits ( were would you get bits like that now)..
But it has been a mission...Good luck with yours by the way do you have any pics .
as promised some shots of it as i went through all the welding...
so thats how its sitting now just waiting for me to start the body filling and then into paint
You certainly werent scared of getting the grinder out were you lol thats a good project youve got going and i really like them wheels not to big i hope ?
mark
mark
i thought i had it bad with some welding.. jesus thats alot. But fair play to you mate. Also if you could send me a link as to where to get a boot floor from id be very gratefull
www.oldcars.de/ is the web adress for motomobil they do all the panels i couldn,t find in the uk...
and the wheels are nice little 14 inch ones , i will still use the pepper pots on it as well, its just nice to have another set..
Did a bit more today... degreased engine bay and removed the harness and somemore odds and ends....
I also did a bit more filling and rubbing down, its getting nearer to primer now...
Most motor factors can get wings, front panels and sills etc.. Its things like inner bays, boot floors etc which are getting harder to find.
Also pop on XRTWO.com mate, few people on there would love to follow this work!
my local motor factors can get the bits but wings are Ł35 each front panel is Ł75 and a bonnet is Ł90, bit over the top as wing where about Ł18 each 2 years ago, thats y i asked where he got them from to see if they where cheaper.
can't wait to see it in paint
Kept looking at the engine pictures thinking those DCNF's don't look anything like mine, then worked it out.
Not that it really matters, other than you'll burn your hands when setting them up, but your DCNF's are fitted backwards.
I got the panels from select panel in walker,,You might get more discount with cash
The bonnet about Ł75..wings Ł26ish...front panel from memory Ł55-Ł60
Thats the way they came fitted up on the manifold straight from another guys car, (Shandylegs) has already posted that they are mounted back to front,and I,ll probably burn my hands setting them up..
I bought the whole engine off the lad just for the top end and carbs,cam,vernier etc,
and judging by how black the pistons where I don,t think he even bothered setting them up..I don,t think he really had a clue,thats why I stripped the head and completly and rebuilt it ..
Thanks for pointing that out guys...
...I,ll swap them round...Iam going to get another weber carb manual ( like i did last time)..and tune and balance them,and once its complete and running it,ll be straight off to be put on the rolling road..
..I bought the whole engine off the lad just for the top end and carbs,cam,vernier etc,
,,try again..
