fao markk wrc pics in zoo 3door
well its early stages but here a few pics not bad for 2 nites work
just hubs and front tiebar antiroll bar left 2moz
then grinder time for inner wings and turrets
That look serious enough! Nice work there. Quite the interesting solution too. Should get the differential to stay in place this. Problems adjusting camber and toe-in/toe-out separately? What about the lower fitment of the coil-over?
i don't s'pose i need to tell you that if you are changing the length of the 'lever' that the coil over is fitted to, and changing the distance away from the pivot, that you will cahnge the effective spring rate. i.e. putting the spring further away from the pivot point will make a softer spring, so a arder than original will be needed.
old coil overs are still on the car they are for sale just havent unblolted them yet
am turreting the rear arches and running a hub and strut like on the front of a cozzy
more pics will follow when i got it done and of course when its all sanded up and powder coated it will look bling bling
Originally Posted by GARETH T
nice work brom
i still got try
a pop up one day to pick my shocks up
i still got try
the reason being i just order my bling rear shocks and gra bodys
nice work brom
i still got try
i still got try
A lot of work there so far.
