focus turbo conversion
Old Feb 6, 2009 | 10:47 AM
rstel1's Avatar
rstel1
Default focus turbo conversion
Hi guys, a mate of mine has a 16. focus and is looking to do a turbo conversion. i suggeted putting a fiesta rs turbo engine in there, he has a 1.8 zetc bottom end and was wondering if you could mate an efi head to the bottom end. hat management would you have to use and hat else ould you need to do the swap?? any ideas as i havnt a clue about focus's
Thanks
Tel
Old Feb 6, 2009 | 12:11 PM
woolford's Avatar
woolford
i have a full 1.8 zetec and gearbox for sale £160 collected that would be a good start
Old Feb 6, 2009 | 06:07 PM
rstel1's Avatar
rstel1
cheers i will let him know
Old Feb 9, 2009 | 05:11 PM
Alex the kid's Avatar
Alex the kid
my car was a 1.6 i put an RS foci engine in my car as my solution
Old Feb 22, 2009 | 10:18 AM
delterflier's Avatar
delterflier
i have a 1.8 zetec.....how wud i go about fiting a turbo??
wud a escort s2 fit???
john
Old Mar 16, 2009 | 09:16 PM
ryu's Avatar
ryu
standard zetec bottom end stick your cvh head on yeha boost boost boost
Old May 4, 2009 | 12:14 AM
HockeyNomad's Avatar
HockeyNomad
for a 1.8 turbo conversion i would look to the focus rs as and example as this is just a 2 litre zetec,
the 1.8 and 2.0 zetec are ssentially the same engine,
first off you need to lower the comp ratio,
http://www.performanceenginecomponen....asp?id=250269
those should help, and will take a good bit of power too,
a set of frs or after market cams for the turbocharging application may prove usefull,
the focus rs exhaust manifold will mate up to the 1.8 zetec head, and you can use the inlet manifold from the frs, the frs has a larger throttle body than the other focus´s, and you will be able to use all the bits available for the focus rs for tweaking some extra power out of your engine, such as intercoolers turbo´s and exhaust systems,
as for a gear box i would look towars sourcing a used frs one or at the very least use the mtx-75 from a 2 litre focus, the IB5 is pants and wont take the power,
and sourcing an frs flywheel so you can use the uprated clutches available would also be a good move.
Old May 4, 2009 | 12:22 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
john
there is alot more involved than just the turbo
Old May 4, 2009 | 12:27 AM
clarke5700's Avatar
clarke5700
standard zetec head and cams have been proven up to 330bhp what sort of power is he looking for?
going to all this trouble of sorcing all this focous rs bit would it not just be alot easyer to carry out a focous rs conversion
Old May 4, 2009 | 01:13 AM
HockeyNomad
or just buy an frs with the prices they are going for just now,
Old Jun 30, 2009 | 01:34 PM
bill hong's Avatar
bill hong
is really useful for me, I am glad to read it here.
Old Jun 30, 2009 | 02:29 PM
leigh-k18's Avatar
leigh-k18
what managment would be need for this frs ecu or after market joby? are the standerd rs manifolds goods as just looking on ebay now and they dont go for mega money unless you get a brand new omp part
Old Jul 1, 2009 | 06:25 AM
HockeyNomad
I would think it would have to be an aftermarket ecu if you wanted to use a 1.8 engine,
Old Jul 1, 2009 | 10:46 AM
leigh-k18's Avatar
leigh-k18
do you think the 1.8 ecu could be mapped to run boost? also do you no if frs pistons fit into the 1.8 head
does any bod no whats the main diffrence between the two heads or do the use a longer stroke on the 2.0 but dimater would be the same?
Old Jul 1, 2009 | 10:51 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Old Jul 1, 2009 | 11:07 AM
HockeyNomad
Lol @ Chip (think isee what Leigh is saying though)
I think a Unichip would give you your best chance of mapping your 1.8 ecu for boost,
the frs pistons will not fit into a 1.8 block this is due to bore size and i dont beleive it is possible to over bore the 1.8 to suit,
the heads are specific to each engine, the 1.8,2.0 and RS engine all have diferent heads, this shouldnt be too much of a problem, but to be honest the main point you should look at is the gearbox in the 1.8 focus its only the IB5 which is not the strongest by a good way, the 2.0 came with the stronger MTX75 box, and the RS has un uprated version of the MTX75
if i was you id go for a full FRS conversion, so many little things you need to do to get boost ona 1.8 the time and money it will take you are best just going for a full conversion i think,
Old Jul 1, 2009 | 01:36 PM
leigh-k18's Avatar
leigh-k18
cheers for clearing some things up would the 2.0 head mate to the 1.8 bottom end or are the the same bottom with jsut diffrent head? and been looking round the pistons for the 1.8 are 85mm and the 2.0 use 86mm so surly could bore the 1mm diffrence out mayb
and as for boxes looked into that two and yes i have got the ib5 box does the mtx75 box mate up to the 1.8 flywheel or would that have to be changed for the 2.0 if that was the case would just got for upgraded and lighter also can get a bc box for the older zetec engines from the gearboxman which comes with a quif lsd two
just after look at the manifolds again i am nearly 100% sure that the focus rs manifold will be a direct fit if i then went for some upgraded pistons and mayb rods upgraded cams focus rs inlet and injectors and then somethink like a Megasquirt ECU and a front mount intercooler would this be enuff for small boost upgrade apart from the box
Old Jul 1, 2009 | 06:22 PM
woolford's Avatar
woolford
the focus rs manifold will fit any 1.8 and 2.0 zetec engine matey
Old Jul 2, 2009 | 03:55 AM
HockeyNomad
Thge heads are all interchangeable on all the zetec engines, the problem comes from the chamber size, it is different in each head, and can throw the compression ratios out,
Second hand focus RS gear boxes seem to be changing hands for circa £500 recently and they come with a Qauiffe ATD diff in them, and also have the benifit or shot peened cogs and revised gear ratios,
Be careful with getting a gearbox from an older zetec as they may have different mounts, for fitment to and escort or mondeo etc, and could need some custom work to get them fitted,
As for the flywheel, im not sure if they will match up or not (i think its smaller), but its a good idea to get the RS flywheel as it will allow you to use the uprated clutches available,
The inlet manifolds are the same on the 1.8, 2.0 and RS engine, all that changes is the throttle body, if youve ever looked at the plastic throttle body on a 1.8 engine then you will see its defo worth upgrading, its the same physical sice as the other ones but the throttle plate is tiny,
the rs exhaust manifold will fit without problem, there are many tubular exhaust manifolds available, from the likes of blueflame, Nortech and Primary Designs,
but i will say it again, it will be easier and simpler to just go for a full rs conversion, and most likely easier on your wallet too,
the standard focus RS engine can see 300 bhp without much work and more than that with a simple turbo upgrade, it has the benifit or forged mahle pistons as standard, the cams are proven to be good right up to nearly 400 bhp,
but if you really are determined to boost the 1.8 go for it, be a good little project,
another thing you could look at is the jackson racing supercharger upgrade if you want boost, might give you enough of a boost to keep you happy,
have aa search on the us ebay should show you what is available and prices etc, they are designed for the 2.0 zetec, but im sure could be used on the 1.8 without much work,
Old Jul 2, 2009 | 08:21 AM
leigh-k18's Avatar
leigh-k18
cheers mate ya i was looking at the rs inlet yesterday and thought it looked the same type as mine just slighty bigger body on it so that would be a worth while mod an way for more air
as for the pistons looked into them thik ill just get a set of forged or mayb as i dont want mega boost a de-comp plate and read the standed roads are good for over 300 bhp
for manifolds there is some cheap ones from the states for £100 quid but think these will crack easy under pressure can also use adapoter plate and use rs manifold off the older zetec engines
and yes as u say would be better to go for full rs converstion but this is just going be a nice little project to take apart the engine and rebuild it my self to get a nice understanding into the zetec and looking on ebay parts for the 1.8/2.0 turbo converstion are easy avaible
thanks for your help mate
Old Jul 2, 2009 | 08:22 AM
leigh-k18's Avatar
leigh-k18
cheers mate would it be best to use a standerd focus rs manifold or a aftermarket one or the older zetec rs manifold with adaptor plates i only looking to run around 200 bhp with a flutter vavle
Old Nov 2, 2009 | 10:31 AM
holty9's Avatar
holty9
wheres the best place to get the adaptor plates from
Old Nov 2, 2009 | 12:34 PM
studabear's Avatar
studabear
probably ferriday engineering
Old Nov 2, 2009 | 01:07 PM
focusrrx87's Avatar
focusrrx87
im currently building a 2.1 zetec turbo that will run about 350bhp wen mapped up al in al wiv out having the pectel t2 mapped it would'v cost me about 3 grand (£600 for the map at grove garage, amhed bajoo) not bad at al considering a focus rs engine wiv 212bhp will cost 2.5k-3k.
theres alot involed in it than u mite think so if ur after a simple fix buy a focus rs engine save u the hassle.
my price of 3k is building it myself wiv my best m8 who just happens to builds engine's so the build it self's cost's nothing, if ur not building it ur self then budget a hell of a lot more.
Old Nov 2, 2009 | 01:11 PM
COCHYN's Avatar
COCHYN
As has already been said, just buy a Focus RS. I'd probably be the first person to say build something that could then call your own, but because of the prices of the MK1 RS you get a hell of a lotta car for pennies!
Old Feb 10, 2010 | 06:24 PM
hineho87's Avatar
hineho87
sorry to jump this thread. Just lookin at options for performance on my 1.8, until i decide if to TC/SC it. Iv got full exhaust/cams mods. Is there a good upgrade to the inlet manifold? Would gettin a bigger TB be worthwhile?
Matt
Old Feb 10, 2010 | 07:24 PM
woolford's Avatar
woolford
Matt
TB not really worth the money for 2-3hp standard inlet is good for upwards of 250bhp so imo not worth changing. is this tc/sc at the min
Paul
Old Feb 10, 2010 | 08:33 PM
hineho87's Avatar
hineho87
Paul
no m8, its n/a at the moment. Wud you get one if its was 2nd hand and good price? Herd its good for improving accelaration?!
Would it help if inlet was ported abit to help the airflow?
Wud ST170 inlet fit the 1.8 zetec focus?
Old Feb 11, 2010 | 07:09 PM
woolford's Avatar
woolford
yes it wouls fit a 1.8 not worth bothering with inlet. you would need cat for st170 unless you get it modified to fit straight onto a standard type exhaust..
Paul
Old Feb 11, 2010 | 07:25 PM
HockeyNomad
Paul
think he meant the st170 inlet manifold, not exhaust.
Old Feb 11, 2010 | 08:41 PM
hineho87's Avatar
hineho87
yea it woz inlet. Iv got the st170 manifold/cat fitted already. Iv bin told the st170 inlet is a big job to fit.
Bin offered a 65mm TB and ported std 1.8 inlet to high with airflow for £80 all in and he will help fit it. Is that a bad price?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
