BD 10 cams??
Old Nov 25, 2004 | 09:55 PM
righthooker's Avatar
righthooker
Default BD 10 cams??
What sort of increase in power would be expected from them compared to standard cams in a 3 door. and would it change the driveability much.I seem to remember reading thet bd cams con be lumpy whatever that means
Old Nov 25, 2004 | 09:58 PM
Ginge !'s Avatar
Ginge !
just finding my feet
i got a bd10 and bd12 cam, i would lioke to know too as i find the car laggy, cpuld this be the cams
but when on boost fook me it moves
Old Nov 25, 2004 | 10:48 PM
gurnE's Avatar
gurnE
Oh dear, do you know what you've just started
Old Nov 25, 2004 | 11:02 PM
Ginge !'s Avatar
Ginge !
nothing by the sound of it
Old Nov 25, 2004 | 11:03 PM
gurnE's Avatar
gurnE
Wait until tomorrow!
Old Nov 26, 2004 | 08:30 PM
righthooker
still waiting
Old Nov 26, 2004 | 08:34 PM
Disabled Account's Avatar
Disabled Account
OK......give me a few mins - I've just got to do a search on my original post.....to save me tpying it all up again..........
Old Nov 26, 2004 | 08:44 PM
Disabled Account
Here you go the "short version"...............I would point out that quite a few on here have had similar experiences with BD10's....then again some people swear by them
IMO Standard cams are fine for up to 380 - 400 BHP.
I have tried BD10's and was VERY dissapointed - mainly due to the lack of mid range torque. This is in context of a Paul Bailey built engine to this spec:
Standard compression ratio, 200 'O' ringed block
STANDARD cams
Big valve, flowed head
Light Blue injectors
T38 (hybrid 360° bearing) rinning 26 PSI
2 WD exhaust manifold/ Maxnex system
I well known tuner suggested that I would be better off with BD10's fitted.....So I purchased the cams from him..................
Decided to do back to back tests at Interpro's rolling road......and YES - the BD10's were dialed in correctly on verniers/adjusted a couple of times too.
Standard cams (with offset keys): 404 BHP......396 ft /LBS torque
BD10's + verniers fitted: 392 BHP......358 ft/LBS torque
Needless to say the STANDARD cams were refitted
Old Nov 26, 2004 | 08:52 PM
BD10's are known as the lag cams. Should be asking what you are losing like most of your lowdown Power/Torque.
Old Nov 26, 2004 | 08:54 PM
righthooker
suprising that,thought there would be a 30 or so bhp increase,wont bother with them then cheers doug
Old Nov 26, 2004 | 09:17 PM
dave cos4x4's Avatar
dave cos4x4
i WAS bidding on some too.
not now.
Dave.
Old Nov 26, 2004 | 09:18 PM
wimwerf's Avatar
wimwerf
and what cam IS better then standard for midrange and/or top end.
Old Nov 27, 2004 | 11:19 AM
wimwerf's Avatar
wimwerf
up
Old Nov 27, 2004 | 11:43 AM
alan rainbow's Avatar
alan rainbow
bd10 inlet and a standard exhaust to keep the midrange and low lag
Old Nov 27, 2004 | 11:47 AM
Demondave's Avatar
Demondave
so what about bd 14's are the standard ones as good or better?? I was looking at get 14's and yes I do have valve cut outs in the pistons.
Dave?
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
