Ok, so it's a 6 paddle clutch.......
I have a 2WD YB Sierra Cosworth which we have done a bit of work on. I am currently up rating the gearbox and at the same to replacing the clutch. We have dyno sheet showing 400 lbs torque and 500hp.
I don't really want to go the twin/triple plate route. Having done a search here, most of you guy's recon a alcon 6 paddle will do the trick.
Question is will I be able to keep it cable operated?
Thanks
Thanks
jessie_rs
11
Jun 3, 2019 04:57 PM
