MK2 XR2
I'd like increase the size of brakes on my car. Does anyone know what will fit that i could possible get from the scrapper or if not from somewhere that wont cost the earth?
Standard RST brakes will fit (not sure if they will under the orig pepper pots though!
Its only gonna got you about Ł70 for the calipers and however much disks/pads are!
There should be a BIG improvement in braking.. if you want to go further... you could use RST caplipers with spacers and 2wd cossie disks
MkV Escort RS2000 discs and Cosworth 4x4 Front Calipers - all bolts straight on but you iwll need 15's to clear the discs.
Please register at www.xrtwo.com forums and this will have been answered in great detail.
Kiran1600E
11
Oct 2, 2015 11:35 AM
