Same problems
Old Feb 1, 2009 | 01:00 PM
2Litre's Avatar
2Litre
Default Same problems
Hi all,
I am still having a nightmare with my idle when cold!!!! I put in a new ISCV and the ecu is sending it a signal, have tested all sensors and changed plugs.(All within range for temps)
I thought I had it sorted as when cold it would start at 1200rpm then drop to 900rpm and run smoothly but then I took it to check co and found that it was 8.8% at idle!! have adjusted it to 3.14% and now when I start it she will run for about 5 seconds and then dies.
I can hear the ISCV trying to raise the idle speed but its all to little to soon, when she s up to temp she runs fine. I have set base idle when warm to 900rpm ISCV unplugged.
The car is running standard cams ingition leads/greys/T3-T45-50-s2-STDO-63 turbonetics 370bhp@23psi)turbo/RS500 intercooler/uprated rad/turbo cooler/044 fuel pump/Champion QC57 plugs (just changed) where Denso's.
The car is a three door ECu L6, at my wits end I have been told it might be the chip !!!
I understand that some engines perfer well can't run well lower co % but 8%!!!
All help and any advise please, gonna lock her away and forget her soon.
Tim.
Old Feb 1, 2009 | 06:05 PM
8 is ridiculous, I would change the plugs, for iridium, I would also to rule it out put a new CTS in there.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
