lowering a focus
Old Jan 30, 2009 | 03:25 PM
anodised's Avatar
anodised
Default lowering a focus
hi all got a lowering kit just springs for my focus and have changed the fronts
but the cant seam to work out how to change the rear springs so does any one know how
thanks
lewis
Old Jan 30, 2009 | 03:33 PM
bassboy's Avatar
bassboy
pain in the backside mate! you will need to ideally take off the the bolt holding the bottom arm at the bottom of the spring...but as normal focus style, they are probably siezed on...which will mean new bushes time as you wont get them out without damaging them!
I gave up on mine and took them to a place with a ramp who put a big bar over the spring while someone put as much weight on the wheel as possible to give it extra room and wedge it out...dangerous but thats the only option we had without taking the car off the road till new bushes arrived!
bassboy
Old Jan 30, 2009 | 03:39 PM
anodised's Avatar
anodised
ok then thanks for that will give it to my mate and let him do it at his work shop
ur right about being siezed on thats why i gave up
im so glad its not my car working on mk4 escorts is so much easier
Old Feb 1, 2009 | 05:48 PM
RS03 PAT's Avatar
RS03 PAT
You unbolt bottom shock bolts and rollbar links then just pull down hard on the top coil of the spring. Be carefull of your fingers. The new shorter springs go in a lot easier
Old Feb 2, 2009 | 10:17 AM
RichieST's Avatar
RichieST
As above, undo the shock bolts and the arb, then put spring compressors inside the spring (there is a big hole in the bottom cup you can put them up through), tighten then up and out it comes!
Old Feb 2, 2009 | 11:46 AM
anodised's Avatar
anodised
thanks i was thinking could i fit them inside the spring its booked in at my mates any was so will tell him thanks for all ur help
lewis
Old Feb 21, 2009 | 09:20 PM
thebigmacmoomin's Avatar
thebigmacmoomin
Mine took 5.5 hours to change. Thats the front and rears. and was done by RadidFit.
Andrew
Old Feb 22, 2009 | 09:59 AM
delterflier's Avatar
delterflier
hi all
ive been thinking of geting my focus lowered too but how low car you go before causing problems(shes on 17"s)
john
Old Feb 22, 2009 | 01:35 PM
thebigmacmoomin
50mm would be ok. Maybe lower on Coilovers.
The best option is the Eibach springs. You can buy them from Fords to no problems with warrenty. They only lower it 30mm, but are very highly recomended on FFOC. A big improvement espically with 17"s. 30mm is ok to still use standard shocks, but if any lower, the shocks would need to be upgraded.
My 2 Focus's both had the Eibach's. They were great. Looked fantastic even when I took the 17"s off and put the standard 15"s back on. Very low.
Andy
Old Feb 25, 2009 | 08:07 PM
BIG.GEOFF.H's Avatar
BIG.GEOFF.H
i did the misses focus rs and i used the big pry bar and got them out and put the coil over springs in
155lee
Sep 6, 2016 11:10 AM
rogerxr3i
Sep 13, 2015 06:56 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
