T34 On a T25 Escort cossie
hi mate
spoke to sall he said you will need
2wd engine loom
turbo
e.c.u.
boost hose's
ignition amp
coil
2wd inlet manifold
crank pulley
dizzy
plug lead's
injector's
i think that's every thing he said
cheer's
lee
p.s sallmotorsport phone no
07760 476163
2wd engine loom
turbo
e.c.u.
boost hose's
ignition amp
coil
2wd inlet manifold
crank pulley
dizzy
plug lead's
injector's
cheer's
lee
07760 476163
WRONG!!!
you need :
a t34 with a 48 ex housing and -31/34 actuator
boost hose from airbox to turbo
cos saph 4x4 or big turbo exhaust manifold
new injectors via msd
plug in chip via msd
uprated fuel pump
msd is motorsport developments in blackpool and is developing this very kit use all standard small t management, why go back to an old unreliable distributer set up when you can keep the benefits of progress!
I'm in the process of collecting the parts to do this very conversion to my own small t
steve
quite suprised sall would say you need to change to a 2wd loom and inlet manifold.
you could also use a BT loom if you choose to change the management to L8/P8, or even have a new loom made for Ł350.
the ST inlet manifold is no problem atall, leave it there as it flows perfectly for bigger power levels.
But as The Youth has said, if MSD are now doing the relevant sofware and equipment needed then its got to be the easiest route.
Scotty Boi, i just activated you registration over on www.EscortRSCosworth.com so hop on over there matey
thanks for the update stu, but as soon as the kit is available I expect your waiting list will grow somewhat!
got my turbo and sorting out the rest of the stuff I need over the next few months...
steve
steve
Billy_RS
16
Oct 11, 2025 09:41 PM
