What paint to use?
Right due to not haveing alot of money at the min i want to paint the inside of my frst project. am i better using basecoat and then clear coat. or one coat i ant really done out like this befor any help will be grate
if your skint you,ll get a respray kit of radiant red in any good paintshop containing 5 litres of 2k colour , 2.5 litres of hardener and a gallon of thinners .
that,ll do the job
that,ll do the job
as above just use striaght colour rather than dicking about with base and clear, its cheaper to buy 2k straight colour and a lot easier to use!! lierally just needs a half coat then a full coat with most or you can do 2 full coats if u wanted. Most paints you usually add 1% thinner to make it flow a bit better too.
Also need to make sure ur using a semi decent spray gun and spraying from 2 - 2.5bar normally but check with the paint supplier first!
will this be any good?
http://cgi.ebay.co.uk/Car-Paint-Cell...2em118Q2el1247
im in the same position atm, sorry to hijack your thread a bit, but i was thinking of using Hammerite smooth to do the inside of my car, anyone tryed this? would it be better to use a primer first or just throw it on as is?
cheers
cheers
if its just for the boot floor just use the respray kit , will probably the cheapest option and as for shine you could paint the full car with it no problem as its good stuff .
but for resprays a always use base and clear but again just matter of opinion as is a dearer method but means you cover your back if any shit lands on the job or that , u can just give it a scuff and recoat it so its all perfect for clearcoat .
Yeah theres no reason why not.
If its for the inside only youmight be better off asking for any mismatched reds, sometimesthey keep colours they have screwed up when mixing and these can be bought very cheap.
rsguy
44
Sep 29, 2015 03:29 PM
