sierra 1.8 cvh bottom pully
Old Jan 27, 2009 | 04:27 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Default sierra 1.8 cvh bottom pully
the 1.8 cvh bottom pully has the trigger wheel built onto it if i sorced the pully and the pick up sensor with the bracket will it fit my 1.6 xr2 cvh?
Old Jan 27, 2009 | 09:16 PM
GINGExR2 T's Avatar
GINGExR2 T
It does fit mate, but you'll need to have the inner and outter faces machined down so as not to touch the inner leg, i've got one on my XR2 turbo and works a treat, i'm luck though as my SECS S8 ECU will read the 32 minus 1 tooth gear, cossie 2wd reads 4 teeth at 3,6,9 and 12 o'clock, bcause of this where the minus 1 tooth is you need to pull the ring off and move it round 1 tooth as the 1.8cvh counts the minus 1, i've seen people pull the tooth gear off and have grub screws put in it so that it can be held in place when refitted.
hope that helps
Ginger
JK12
33
Apr 26, 2021 12:09 PM
dombanks
Sep 21, 2015 08:38 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
