ford focus mk1 brake light problem?
Old Jan 27, 2009 | 12:36 PM
paceo's Avatar
paceo
Question ford focus mk1 brake light problem? UPDATE PICTURES 28-1
got a small problem with a mates focus, when he pushes the brake pedal to stop, every now and the the handbrake light comes on, ive got my ideas what it is, i just want to see your views.
its a focus 1.6 zetec 1999!
Old Jan 27, 2009 | 01:34 PM
focusv8's Avatar
focusv8
You mean the Handbrake / LOW FLUID light comes on.
Brake /Clutch (combined) fluid is low.
Either the Front pads are getting low or the clutch master or slave cylinder has started leaking.
Old Jan 27, 2009 | 02:02 PM
paceo's Avatar
paceo
where is the cylinder located on these motors?
Old Jan 27, 2009 | 02:07 PM
focusv8's Avatar
focusv8
Master cylinder is on the top of the clutch pedal, they'll be fluid dripping down the pedal if it's that.
Clutch slave is inside the bell-housing, gearbox out job, fluid dripping out the bottom of the box if it's that.
Old Jan 27, 2009 | 02:10 PM
paceo's Avatar
paceo
cool mate, just hope the brake fluid is low or pads are low
forgot to mention its automatic, no cluth pedal
Old Jan 28, 2009 | 02:31 PM
paceo's Avatar
paceo
just found this leak guys on the brake pedal, but the pedal is not wet in fluid and the carpet is not wet either. looks like the master cylinder then.
the brake fluid was very low below minimum but not much has leaked though! ive looked at the brake servo from the outside and nothing is leaking there.
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
