ABS ecu
Live long and prosper!!
anyone?
having probs with pulsing at slow speeds checked everything still no joy
Whats the story behind the bias valve at the rear and why was it moved to the front on later cars?
I'm running a 350 4 pot on front and 4x4 on rear if that helps any
Paul
Paul
the valve arragement was purely for heat issues
you've got the ones with the integral valve assemby and the ones with it split on the passenger side
plus you've got the orientation of the bits on the main block itself
the pulsing is probably more to do with the vavle assembly being blocked up, but i've no idea how to go about unblocking it other than finding a decent replacement
Starting to get to me a little
Paul
how did you bleed the brakes then?
you may still have an air lock in the valve block
you do know that you need to have the ignition on at pos1 to prime the pump to pressureise the rear lines and then put your foot on the pedal to open the valve to let the fluid through don't you?
Simon i would be gatefull if i could borrow it again lol
Pm me when you find it thanks
Paul
Pedal pulsing and antilock action at low speeds (below 10mph?) means the ABS sensors are giving innaccurate information to the ECU, which is triggering the anti-lock system. The anti-lock should not activate at very low (maneuvering) speeds because the electrical signal from the sensors is not strong enough to give the ECU any information.
And no there not furred up or corroded face of hubs are perfectly clean too
Paul
I have a fault with one or more of my ABS sensors and brings the ABS light on intermittanly and pedal pulses sometimes when coming to stop at traffic lights etc.
Whats the best way to check the sensors? Checking the resistance with ohm meter?
What should it be?
What should it be?
Right then had a think and a fiddle the sensors are not earthed via the bolt or anything else multimeter showed this to be the case
Also there are no metal to metal joints on the sus to go back to earth all bushed
the only thing i can try now is that the sensors do and can rotate a little once the bolt is loose approx 3mm either side so will have a check of these and report back
James, I've 2 spares ecu's so thanks
Paul
Paul
If it's the same issue you mentioned the other day in another thread did you try what I said and unplug the ABS ECU to test. This is a common problem it will be one of the wheel sensors at fault sometimes they just need a clean if not you will require a new sensor. If you have access to a multi meter there is a way of testing them. I think you measure the resistance, it will defently be explained on here if you do a search.
Kind regards,
Martin.
as you say paul, it doesn't seem to due to bushes etc. however, the sensor itself has a metal ring where the bolt goes through and the back of that and where it bolts to needs to be clean. sounds like it won't make a difference, but did on 2 of my sierras that had the same problem.
Nick that would be due to the "air Gap" then mate i've tested with a multimeter and it don't earth to either connections but if teres any corrosion on the alloy ring that will hold the sensor out enough to fook it up
Paul
Paul
too much grease will afect it
especially when you remember that it's bearing grease and it can be thicker than ususal, and it gets dirty
on the rears it's worse as if you get a bit of debris into it when you pull it out it may just think that the cars wheels are permamnently stopped beause you can't see as well as the fronts
Paul
Paul,
Put a multimeter on the sensor wires on resistance.
Observe the value the wiggle the wiring vigourously and see if the values change significantly.
Often the sensors fail not because of the sensing head but the wire itself because it gets a pounding from all the
bumps in the road and when the steering is turned.
I had this twice on my sierra and managed to fix them by replcing the cable by cutting of an inch at a time and retesting.
(Carefull of polarity).
Obviously, if you do this, its at your own risk
Paul,
Paul
Been out again and checked all sensors all clean all read ok with multimeter light stays out even fitted washers were i removed rear splash shields cos i went 4x4 on the back STILL NO JOY!!
could it be that i have very small radius on the front brake flexis??
Any help would be great ta
Paul
Paul
Paul
Paul
What was the original problem again?
The Teves Mk 2 on the Sierra has no Keep Alive Memory, so it doesn't remember a thing when it's turned on the next time. As a result, it stores no fault codes - all faults that are indicated are 'live', not old.
Have you done the measurements at the ABS ECU's multiplug? If not, do that - it's all very well a sensor 'checking out', but if the ECU can't see it because of a wiring fault, it might as well not be there.
- Wheel sensors should be anywhere between 800 and 1400 ohms.
- The outlet solenoids in the valve block should register between 2 and 5 ohms.
- The inlet solenoids in the valve block should register between 3 and 7 ohms.
- The mail valve should be between 2 and 5 ohms.
- The fluid level switch (two pin plug on top of the fluid reservoir) can be measured across pins 9 and 10 of the ECU multiplug - this should be a closed circuit when the fluid level is at max, and open when it's higher or lower. If this switch is open, the ABS will be disabled. This was the problem with mine.
- The wheel sensors create a small AC current. At 1 revolution per second, the AC voltage from each sensor should be around 0.2 volts.
- To check the sensors and their cables aren't earthing out, measure the resistance between pin 1 and pins 4, 5, 6 and 7 - should be infinite. The cables are shielded co-axial cable, so if the sheath has worn through, a sensor may be earthing.
- Check the earth connection - meter 11 and 1 for resistance - should be 0 ohms.
- Measure resistance for these pairs to check sensor resistance: 4 & 22, 5 & 23, 6 & 24, 7 & 25. Should be within the tolerance noted above
- To meaure the resistance of the valve block solenoids, measure the resistance between pin 11 (earth) and pins 15, 17 and 35 for the inlets, and between pin 11 and 33, 16 and 34 for the outlets. Tolerances noted above.
Thanks the prob is pulsing pedal at low speeds below 10 mph while coming to a stop
all was fine till i replaced all discs and pads 350 on front and 4x4 on rear and with braided lines aswell
i've heard about the level being incorrect could cause issues but would that not put the light on ?(does when unplugged)
My flexi hoses on the front have a very tight radius could this be an issue?
Paul
Paul
Only if you had a problem before you changed your discs/pads.
That symptom means that the wheel sensors are feeding false information to the ECU, as below 10mph, there shouldn't be a strong enough signal for the ECU to determine whether or not antilock action is required. It's very unlikely your hoses are to blame because what you're describing is caused by the ECU falsely believing there is a wheel lock situation.
I'd suggest that either one of the sensors is defective, more likely the front, or, there is a poor connection between it and the ECU.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
