2wd cosworth quaife rear diff breaking complete car
Old Jan 25, 2009 | 05:52 PM
abdr500's Avatar
abdr500
Default 2wd cosworth quaife rear diff breaking complete car
2wd cosworth Quaife rear diff std ratio re built done few hundread miles
£800
delivery £30
Old Jan 25, 2009 | 06:03 PM
sortedsaff's Avatar
sortedsaff
hi mate . you say breaking complete car have you got a gearbox?
Old Jan 25, 2009 | 06:13 PM
abdr500's Avatar
abdr500
yes but due to the type of gear box it expensive its not a t5 and ment for over 500 bhp
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
if he hasnt tony , drop me a line , i may know of one in the cpl weeks ,
beef
Old Jan 25, 2009 | 06:41 PM
abdr500's Avatar
abdr500
i have a tremec tko 600 gearbox just fitted done less than 700 miles comes all ready adapted to bolt to a cosworth
Old Jan 25, 2009 | 07:12 PM
mechanic28's Avatar
mechanic28
why u breaking fella
Old Jan 25, 2009 | 09:40 PM
JonnyBravo's Avatar
JonnyBravo
I messaged you on turbo sport about the under car fuel swirl pot, have you anymore info on that please.
Thanks
Old Jan 26, 2009 | 12:14 AM
abdr500's Avatar
abdr500
its mike rainbirds old fuel swirl pot it works perfect for me and is alloy i did measage you ther
Old Jan 26, 2009 | 12:22 AM
JonnyBravo's Avatar
JonnyBravo
Actually you didn't but not to worry.
I think Mikes got some pics of it on his thread, ran 2 stock external pumps didn't it ?
Old Jan 26, 2009 | 12:33 AM
abdr500's Avatar
abdr500
1 intank 1 external his new set up runs the 2 i belive
Old Jan 26, 2009 | 10:35 AM
JonnyBravo's Avatar
JonnyBravo
I've emailed Mike for pics as I need a rough idea of size before getting it, if its ideal I'll definately be interested the owner doesn't want a swirl pot in his boot
Old Jan 27, 2009 | 10:03 PM
abdr500's Avatar
abdr500
does no one want a quaife diff for ther cosworth
Old Jan 27, 2009 | 10:57 PM
SCOTT81's Avatar
SCOTT81
add luv yin mate but no got 800 lol
Old Jan 28, 2009 | 06:08 AM
Stakis's Avatar
Stakis
lower the price to 450-500gbp and we can talk further.
Old Jan 28, 2009 | 07:06 AM
johnyjn's Avatar
johnyjn
How much do you want for the gearbox ?
Old Jan 28, 2009 | 08:28 AM
abdr500's Avatar
abdr500
brand new diff like this would cost£1.300 so go away
Old Jan 28, 2009 | 08:29 AM
JonnyBravo's Avatar
JonnyBravo
£450-£500
Any chance of a pic of this swirl pot please ?
Old Jan 28, 2009 | 08:30 AM
abdr500's Avatar
abdr500
offers for a £3.000 gear box thats done less than 700 miles it basicaly new
Old Jan 28, 2009 | 08:33 AM
abdr500's Avatar
abdr500
£450-£500
i keeping saying i will try but have no time its a custom made one works well i paid double what im selling it for so its up to you if its any help its a round tank with fittings on the end the fittings alone would cost a bit so its a give away at the price
Old Jan 28, 2009 | 08:35 AM
JonnyBravo's Avatar
JonnyBravo
How much posted then mate for just the tank ? I won't need the pump
Old Jan 28, 2009 | 08:40 AM
carlo's Avatar
carlo
I could do with the diff but wont be for a couple weeks if it sells then thats fine.I possibly have to buy another super 8 ecu , plus coil pack conversion this month.
I take it its a plated diff?
Old Jan 28, 2009 | 08:41 AM
abdr500's Avatar
abdr500
£10 to post
Old Jan 28, 2009 | 08:43 AM
abdr500's Avatar
abdr500
its a quaife diff for a 2wd that hasnt done more than 700 miles if was re built by reyland motorsport its to cheap at £800 new these are £1.300 plus your old diff
Old Jan 28, 2009 | 08:46 AM
JonnyBravo's Avatar
JonnyBravo
Originally Posted by abdr500
£10 to post
As soon as I've spoken to the guy who's car I need it for I'll drop you a PM, thanks
Old Jan 28, 2009 | 09:46 AM
carlo's Avatar
carlo
I know its quaife whats uprated on it, Is it plated
Old Jan 28, 2009 | 09:59 AM
JonnyBravo's Avatar
JonnyBravo
Carlo:
Quaife do not make a plate diff, its a ATB (Automatic Torque Biasing) Differential, the same as a FRS has as standard and the same as Rainbird uses in his Escort, its non serviceable as it never goes wrong unlike a plate diff.
Gripper and Tran-x to name a few make plate diffs.
The diff is standard size and fits in a standard 7.5" casing, I don't even think Quaife make a uprated rear casing unlike the thick wall front diff casing they do make which I think is what your possibly getting confused with.
It also uses a standard fitment cwp and in this case runs standard gearing
Paul :
I've spoke with my mate and we need to see what room he has before he commits to buying it, its hard to say without seeing a pic really but if you sell it we'll just have one made, cheers anyway
Old Jan 28, 2009 | 10:20 AM
carlo's Avatar
carlo
Thanks i will get back to you
Old Jan 28, 2009 | 10:21 AM
Kelv's Avatar
Kelv
Almost there!
Spot on description there James.
as an extra bit of info, they dont make a thickwall casing as the standard rear casing is plenty strong enough to cope with whats being asked of it, where as the front casing was crying out for a bit of extra strength!
you can use a different CWP as my 7" Rear Quaife ATB has had a 3.9 CWP fitted
Old Jan 28, 2009 | 11:55 AM
JonnyBravo's Avatar
JonnyBravo
Cheers kelv !
The best mod a friend did to his 3 door was fit a 3.9 cwp, totally transformed the car as it makes the most of the engines power, tib still managed nigh on 180 at brunters using that gearing which is as fast as you should ever need to go unless your a top speed queen.
Old Jan 28, 2009 | 03:59 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
Carlo:
The swirl pot is off Mike Rainbirds Escort, I think there is pics in his resto thread. He has a different on in the car now.
HTH
Old Jan 28, 2009 | 04:16 PM
JonnyBravo's Avatar
JonnyBravo
I've already PM'd Mike and he doesn't have any pics of the old setup, all sorted now though I think
Old Jan 28, 2009 | 07:23 PM
Stakis's Avatar
Stakis
how you get 1300gbp???? the diff from quaife without any discounts go for about 750bgp. if you buy it o company, you save VAT. dreamer
Old Jan 28, 2009 | 07:56 PM
gibbo frst's Avatar
gibbo frst
i was quoted around 1300 for one from cts. think 1k for unit about 150 machining and 150 labour .. was last year so may have gone up so seems a good price to me..
Old Jan 30, 2009 | 12:32 AM
abdr500's Avatar
abdr500
hi i have started a new post with pic up of some bits for thoes that were asking for a photo of the fuel swirl pot shell bumpers ect
Old Sep 13, 2009 | 02:20 PM
b11cos's Avatar
b11cos
is there proof its a quaife diff, if so ill take it off you!!
Aug 14, 2015 07:29 AM
xr4x4rs
Aug 6, 2015 09:03 PM
COLEYST200
Aug 3, 2015 08:55 AM
Old ford
Jul 31, 2015 06:50 AM
