Help with Cossie management on a S2
Old Feb 20, 2004 | 03:30 PM
Default Help with Cossie management on a S2
Due to my head being warped the head gasket has just started leaking oil, i've opted to run an efi head and inlet and cosworth management.
I think I have the requirements list just about sorted:
ECU,
Engine bay loom,
Injector loom,
Fuel pump,
Fuel pressure regulator,
Injectors (Yellow),
Anti stall valve,
Throttle body,
Coil pack,
Throttle position sensor,
MAP sensor,
Air charge sensor,
Engine coolant temp sensor,
Engine speed sensor (TDC),
EFi head, inlet manifold and fuel rail,
1800 cvh bottom pulley.
I’m hoping to get all the cosworth parts off a late 2wd or 4x4 meaning its sparkless ignition.
I just had a few questions:
Is there anything else I need?
Will the kent cvh35 cam from my mfi head work in an efi head?
Will i need a single piston dump valve?
I’m not particularly in the know but am learning rapidly, I do have a mechanic who knows quite a bit about Cosworths helping me.
If anyone has done this or knows how to, any advice would be of great help.
P.s. my current setup is 1620cc low comp bottom end, hybrid turbo and chip, dump valve, oil separator, swirl pot, pace radiator and intercooler, silicone water and boost pipes, kent 35 cam, K&N, 3" exhaust. I’ve got the efi head and I’m having large valve with 3 angle seats put in it and skimmed.
Andy.
Old Feb 20, 2004 | 04:34 PM
PJay's Avatar
PJay
yes
either that or none at all
Don't have the head skimmed if it doesn't need it this will RAISE your compression
Old Feb 20, 2004 | 04:50 PM
HI, YOU WILL ALSO NEED PHASE SENSOR,
Old Feb 20, 2004 | 05:11 PM
PJay's Avatar
PJay
Not if using a coil pack, you'll require a cam sensor instead
Old Feb 20, 2004 | 05:28 PM
HI,
GOOD POINT, i thought u were calling your std coil, a coil pack as some of your sensors listed are not correct name ie stall valve , what type of cossie management are u using weber marelli, or ford eec4,
Dave,
Old Feb 20, 2004 | 05:31 PM
thanks for the quick replies, i was planing on using the weber marelli out of a g reg saff 2wd.
Old Feb 20, 2004 | 05:32 PM
unfortunately, the head needed a skim
Old Feb 21, 2004 | 10:06 AM
How much do you think all the cossie stuff (ECU, loom, sensors, etc) should cost? And where would you recommend I get it?
Old Feb 21, 2004 | 12:29 PM
PJay's Avatar
PJay
Varies from place to place, personally i would get all new sensors, have you thought about aftermarket management? some of these come with a loom at very good prices now
Old Feb 21, 2004 | 02:14 PM
The best price i have is 450 for all of it, bar the fuel pump ,as i was going to buy that new, not much difference in price and the head + inlet. How much would an after market management system be? what advantages would one have? are they as good as the cossie setup? and where would i get one from?
Old Feb 21, 2004 | 02:18 PM
PJay's Avatar
PJay
There are several options on aftermarket management some of which are better features than cosworth and some that arn't, cossie management is capable of most things
Old Feb 21, 2004 | 02:27 PM
is there anyone that you would recommend? or any info online i could read?
Old Feb 23, 2004 | 07:02 AM
After looking at Omex aftermarket management, and although it looked very good, I decided it was a little to pricey for my budget!
So I bought all the cossie stuff last night. The guy I bought it off said that it would still require a modified dizzy tho! I just hope I got the correct stuff now!
The ECU reads IAW 045 (weber marelli). Is it possible to still do the conversion with this ECU, loom and sensors? and do I need a modified dizzy?
Cheers,
Andy.
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
