Cosworth bits, escos, 2wd bits
Old Jan 24, 2009 | 10:14 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Default Cosworth bits, escos, 2wd bits
All items located in Birmingham B24, Collection only on heavier items.
Pair BD10 cams (to fit 4x4 head), used but good condition.
Escos Front Bumper, imperial blue, very few miles on it, bare, paint ok.
Escos fogs, used but clean. (sold)
Escos 'Aeropack Deletion option' bootlid, has the same body as escos but without the holes for the top spoiler, could be made to fit wing easily. Comes with glass, wiper internals and wiring (needs attention to connectors on 3 prong external connector), imperial blue but would need paint as scratched a bit.
escos front x-member.
Escos Bonnet, imp blue, tiny ting little dent easily sorted at bodyshop.
Bonnet Undermatting, great condition.
Escos Bonnet Vents, imp blue.
Sunroof mechanism, manual with glass, handle bust but mechanism good.
Rear Bumper, imp blue, good condition would probably need paint to be mint. (sold)
Standard 2wd saph radiator, good condition comes with good fans.
ST escos fuel rail, paint peeling & needs new regulator. (sold)
ST escos 70mm Throttle body, complete with ISCV and TPS, great condition hardly used.
Fuel Tank & neck.
Fuel Pump Straps.
All std fuel lines, good condition.
ABS pump unit, block & lines GC.
Escos front calipers & disks, disks hardly used as are pads, calipers in GC and GWO.
4x4 Engine arms.
4x4 Saph propshafts.
2wd Propshaft GC.
Escos std Front shafts, low mileage.
Xr4x4 Front Shafts (have xr4x4 hub and tcas still attached to them).
2wd Rear calipers and disks GC.
Saph rear spoiler.
2wd ARB.
4x4 sierra steering columb.
xr4x4 arch liners, may fit saph or escos with trimming??
Turbo cooler, Was on Rods 200+mph saph, will fit escos if you have 500 style cooler. polished ally, could do with a bit of a buff, has few marks from storage. (sold)
OFFERS on items VIA PM only please.
Will poss swap if you have........ carbon/kevlar bumpers bootlid, alloy header tank, alloy pas bottle, grp A coil, Gen T4, big rear brake kit, hydraulic handbrake, stack or similar dash, 2wd starter
Old Jan 26, 2009 | 06:05 PM
SillyFezzaMk1
Rubber Rhino Crew
Bump
Old Jan 26, 2009 | 06:12 PM
dom123's Avatar
dom123
wasnt the icv on the top of the plenum not the throttlebody mate.
Old Jan 26, 2009 | 07:04 PM
Tev's Avatar
Tev
can you pm me the price your after for the 2wd prop cheers jay
Old Jan 26, 2009 | 07:17 PM
SillyFezzaMk1
Rubber Rhino Crew
no mate, its a single piece unit, tb, iscv & tps all in one. The one with the ISCV on the plenum was the rs500 IIRC
Old Jan 28, 2009 | 07:06 PM
SillyFezzaMk1
Rubber Rhino Crew
bump
Try me guys, open to offers.
Dan
Old Feb 2, 2009 | 04:44 PM
SillyFezzaMk1
Rubber Rhino Crew
boing back to the top
Old Feb 5, 2009 | 10:21 PM
antilag420bhp's Avatar
antilag420bhp
hi mate is the abs pump of 2wd or 4 cheers ross
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
