fuel pump
Kind regards,
Martin.
sorry its a 1991, i have checked the crank sensor.and tapped and wiggled the relays but still nothing any more ideas ,thanks martin ,im thinking new pump do i have to take the tank of to check
Not to sure about the fuel pump location on Fiesta's, if it's gravity fed like the Cosworths it will be in a cradle fitted underneath the tank, if not I guess it will be in the tank try.
If it's the latter if I were you I would check that it's deffo not the relay and measure the output on the wiring up to the tank if so this would indicate fuel pump fault.
Otherwise you won't be best happy if the fuel pump is ok and your got a fuel tank to re assemble and re fuel
Kind regards,
Martin.
Kind regards,
Martin.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
