Alloy rad! Which one?
just when all was going so well! I have discovered my rad is leaking when under pressure.
So with new being required i may as well do it properly so anyone have any idea wat the Air Tec rads are like?
I have the Airtec front mount intercooler and am impressed with the quality for the money!
Jonnie! Hows it going mate?
Unless you want the looks of an ally rad your best bet is a new copper rad, copper dissipates heat faster than ally so when your up to temperature the ally rad will actually cool worse than a standard copper one...... but they do look nice
Karlos - all good ta mate! Urself?
is that the case? Well to be fair i just want wot ever is the best option, everything else is ally so just went with it.
With the 'cooler and all the other clobber you wont actually see much of the rad so im not to fussed!
Is the copper rad simply a standard one?
Yes mate i'm good! Just got an airleak i need to sort out at the moment, XR3i box is still holding out! lol
Yeah copper rad is just a standard one (about £180 from ebay i think), i dont know how much difference it makes in actual degree's C but it will cool better than the ally ones once up to operating temps for sure!
haha good, glad to hear it!
Well if thats the case i will have a look for a standard one! Really wont see it once fitted so all good!
Iv got loadsa silly spares in my garage mate (although few MFi) if ya ever need anything!
karlos - well i have stacks of hose so if ya get stuck gimme a call
Antony215 - thanks for ur comments, its actually leaking from the sides where the centre sort of 'wraps round' so think its a new one needed
wheres yours leaking from,the core or the end tank
if its the core then any radiator specialist will recore it for approx 80 quid
if its the end tanks then get a copper end tank made up,as the plastic end tanks are pants,cost me 35 quid to get rad sorted with a new end tank
Well from what i can see its leaking from the side tanks where the sides 'hook' around.
Iv only been able to see when the car is idling on a ramp and the time i'd noticed it leaking was after driving it home.
Is was only dribbling however i asumed it would get under more pressure while being driven, not just idling!?!?!
ive just found a place near me that will recore my rad for £98.00 plus vat in copper, he will also off a small discount for anyone else who wants one. Just letting you know if anyone is interested, he also said in his opinion the copper is better than alloy rads at keeping cool once up to temperature.
