Water cooled turbo pipes
Old Jan 17, 2009 | 01:46 PM
01dwilkinson's Avatar
01dwilkinson
Mk3 capri 3.0l
Default Water cooled turbo pipes
Hello, just recently bought my 1989 escort rs turbo which if im right in saying are supposed to have water cooled turbos and have noticed that the water pipes that are supposed to go to and from the turbo have been cut and blocked of with bolts is there a reason that this has been done, also do most of you on this forum all keep your turbos watercooled.
Old Jan 17, 2009 | 02:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Not a problem mate so long as you let your turbo cool down for a minute or two if you've been giving it beans.
Lots of people disconnect the water cooling because in the warmer weather if your running high boost it keeps your water temps really high.
Old Jan 17, 2009 | 02:26 PM
01dwilkinson
Mk3 capri 3.0l
right cheers for that, was getting a bit worried about it.
Old Jan 17, 2009 | 02:52 PM
orionmojo's Avatar
orionmojo
you might find that one has sprung a leak (especially if they have the chrome "rs" heatshield over the manifold cos it rubs on the top one) and they've blocked them off for that reason.
Old Jan 17, 2009 | 05:42 PM
antony215's Avatar
antony215
Escort Rs Turbo
It could just be someone has fitted a S1 T3 they were oil cooled only
Old Jan 17, 2009 | 08:27 PM
studabear's Avatar
studabear
mines like that
Old Jan 21, 2009 | 08:20 PM
johnboy19's Avatar
johnboy19
Why would you want to keep you water temps high thought
Old Jan 21, 2009 | 08:32 PM
studabear's Avatar
studabear
thats the point, to keep water temp lower
Old Jan 21, 2009 | 09:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lol yeah thats exactly the point
Old Jan 22, 2009 | 01:58 PM
bigryrs's Avatar
bigryrs
RSHoleinator
i might just do that with mine cos i cant get a decent seal on my bottom pipe it just leaks all the time so il just block them off completely
Old Jan 22, 2009 | 02:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yup mine are blocked off, think i used a M8 bolt in each one and a Jubilee clip.
Easy!
Just remember to let your turbo cool down for a minute or two after giving it pasty and you'll be ok!
Oct 9, 2015 07:38 PM
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
Aug 19, 2015 06:25 PM
